20 Most Recent
Compaq iPAQ H3630 Pocket PC Questions & Answers
The battery doesn't work
okay so heres the deal o have this h3800 Compaq pocket PC and it has been left uncharged for a while but now that i go to use it i will only work when plugged in.
I have no charger
Hi
You need to get a new charger
You can not charge it via usb or other type
of chargers you need the original only
pls do n;t try aftermarket chargre you will lose guarranty
My iPAQ won't turn on no matter what i do.
If you are saying it heats up the it sounds to me like the battery is not holding a charge anymore.
Try to remove the batter and place the pocket pc in its cradle and turn it on if it works then you can be sure it's the battery.
You can probably pick up a batery on Ebay real cheap. Or swing by your local BatteryPlus store and they can test the old battery and probably buy a new one in the store.
I hope this helps
Have a great day.
I bought it from a friend but it wont go past a
First thing you can do is force quit, by holding the Home button.
If not resolved, try a forced restore. Plug it in to your Mac/PC and hold the Home button until the "Dock to iTunes" screen shows on your iTouch.
How do I setup my HP iPaq 2210 to access the
First of all, you should install the driver for your wlan-11b card to your PDA. (There should be a CD given with the wifi card, or you can download in online through the card's brand's website, ex. .cab file for a Spectec SDW821 Wi-Fi Card) At this step, you should be carefull with the version of windows mobile on your device and the driver's version for windows mobile. After that, you should plug your wifi card to your PDA's SD slot, and your PDA will recognize it. So you can go to your settings, and there you can search for a wireless network.
Memory upgarde ipaq 3630
Hi there
1) Where can you purchase the memory? - you can buy them at many stores such as Walmart if you come from USA or Game if you come from South Africa.
2) How much can you put in? - Depending on the model of your Pocket Pc you can put up to 1gigabite but they usually come with only 64mb.
3) How to install it - You must first buy an HP expansion pack which you place on your Pocket Pc and you place the extra memory card in the expansion pack.
4) Where can you download software for it? - The memory card comes with the software installed already
Kind regards
Dustin Ellse
Manual
need a manual for compaq ipaq 3630
Targus Stowaway Keyboard
Hi there
Today I am going to show you how to get your Targus Stowaway Keyboard to run on your Pocket Pc! Go to http://www.limewire.com and simply download Lime Wire, once you have done so, search for Targus Stowaway Keyboard Driver for Pocket Pc (I searched for: Targus Stowaway Keyboard Driver for Compaq Ipaq H3630 Pocket Pc), as this is my Pocket Pc model and make. Then go to http://www.google.com and search for Microsoft Activesync, find a website where you can download this for free and then download it and set it up and have it in "sync" with your Pocket Pc. Then, while you are still in Lime Wire, open the file you just downloaded and let it do it's thing, once you have done this, your Desktop Pc and your Pocket Pc will tell you to reset the device (Your Pocket Pc), when it tells you to do this, it does not mean you must do a "Hard Reset" (A "Hard Reset" is when you switch off the device at the bottom of the pocket pc, which makes you lose all of your programmes and all the stuff you have on your Pocket Pc) what it means is that you must turn off your device at the on/off button at the top of your device and then turn it back on. Now your keyboard should work! Once you have done all of this, you might have a problem with your menu (Your menu is in the middle of your screen), to fix this problem go to "Settings" and click on "Menus", once this has opened, search for "Stowaway" and un-tick the box next to it. If you have any more problems or questions about your Compaq Ipaq Pocket Pc or your Targus Stowaway Keyboard please send me an e-mail at
[email protected]Kind regards
Dustin Ellse
Using a keyboard
Hi there
Dustin Ellse
I have an ipaq 1950...
It is ovbvious from the Picture that your screen is cracked. You will not be able to comlete the alignment without fixing that first. Contact HP or a local HP repairer
