20 Most Recent
Compaq iPAQ H3765 Pocket PC Questions & Answers
Where do I find the model number?
Look on the capsule-shaped sticker on the back. Near the bottom, left, you'll see under the part number ('P/N') the word 'MODEL' and then a number ('3765') under that.
Compaq Ipac pocket PC 3765
You'll need a very small flat screwdriver and ease the case open from the back center to the corners. Then the sides should pop loose.
Compaq ipaq
hi i am wolson so i have a problem with my pocket pc so i need connect it to the internet but i can't can you explain what i suppose to do please
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
I want to install xp on compaq nx 6310 give the procedure with pendrive
2006 PC (HP.coM) 16 years old.. ouch.
XP (microsoft) is now a horrible virus magnet, and there is ZERO support now, are you using the last XP earth 2020???
gee google that. 2001 to 2007 was XP rein , vista 2007
I bet there are 1millons of web site still with XP usage .(old topics)
google them. but Microsoft purged theirs.
it is not sold at all, so how in the world can you get the installer on any pen drive, and XP installed from CD not pen..
worst of all XP installer, can not us 99% of all USB ports and then only half after the install (unless you force them via F6 and floppy drive with xp drivers on the floppy for THIS PC)
to use any relic PCs run LINUX> not XP
