20 Most Recent Compaq iPAQ H3650 Pocket PC Questions & Answers
http://www.retrevo.com/support/HP-h3630-PDAs-and-Handhelds-manual/id/281bh329/t/2/ here you go download it then open it!
i think its pdf but im not sure :S hope this helps :
Compaq iPAQ... | Answered on Oct 23, 2010
http://arstechnica.com/reviews/4q00/ipaq36x0/ipaq36x0-1.html
is a good way to start as well as the store where the itemwas bought.
Compaq iPAQ... | Answered on Jun 22, 2010
You might try http://www.retrevo.com I know they have a manual for it.
Compaq iPAQ... | Answered on Sep 13, 2009
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=215348&prodSeriesId=96479
Get your manual HERE
Compaq iPAQ... | Answered on Apr 25, 2009
jihuifhiouheiofjfe
Compaq iPAQ... | Answered on Nov 22, 2008
turn off the unit, and then turn it back on. If this does not help, reset your nuvi.
1. Disconnect the device from external power.
2. Press the Reset button on the bottom of the device
3. Connect the device to a power source.
Compaq iPAQ... | Answered on Jun 26, 2008
Y have a similar case, after replacing the LCD screen of one of my customers. The image is upside down and mirrored. We are going to test a new panel.
I'll let you know.
Compaq iPAQ... | Answered on May 30, 2008
Could you write down the part number for the old and new screens to check for compatibility?
Regards,
Compaq iPAQ... | Answered on May 28, 2008
I'm not sure if Pocket PC Explorer is like the full Explorer version, but if you go to the Internet Options Control Panel, select the Advanced Tab, Scroll Down to the Multimedia Options and there are selection options for showing pics, playing sounds, etc. Hopefully, Pocket Explorer is similar and all you need to do is activate the option to show pics. Good Luck!
Compaq iPAQ... | Answered on Sep 12, 2005
Man this sucks I've been trying to make it work and it just doesn't seem to be working. I don't get it, why does it work on power supply but not on its own away from the supply. Help.
uninstall ActiveSync and all of its remianders (for details see here: http://www.pocketpcfaq.com/wce/activesync3.1remove.htm ) Then make a new install of AS.
Compaq iPAQ... | Answered on Sep 11, 2005
use wired Ethernet, so it works. easy.
wifi is far more complex.
best is to own the router, you have.
then login to it and set it up for wpa./wpa2
wep off.
and a nice password for wifi so others cant hack it. in the hood.
then use those credentials all all your toys. xbox, PCs and cell.
that is the best way
the access point is covered in you manual for the router
there is AP button there, you push.
the PC in question my guess is the drivers are no good.
missing wrong, or corrupted.
no PC full model stated.
no OS stated
no router stated.
so answers will be weak to wrong,.
Compaq Computers... | Answered on Jan 20, 2020
Start your web browser,
find options, open options.
Find and open search.
On this page you will see
"Use the address bar for search and navigation"
and
"Add search bar in toolbar"
which puts a separate window next to the address bar with search written in it..
Choose which one you want to use
Go down to one click search engines.
You will see a number of search engines in a box usually ticked.
I use a search engine called Duckduckgo because it does not keep any data on me...
under the search engines box there is a line in blue "Find more search engines".
Click on the blue line and you will see a list of different search engines, click on one and a new page will open up and you follow instructions to install the search engine.
In she search engine box, if you do not want use one of engines just un-tick it
Hope this helps
Regards
Geoff
Compaq Computers... | Answered on Jan 11, 2020
b> Copy-protected DVDs prohibit people from copying them, which is piracy. Copying a DVD to sell or even to give away is illegal. You can play copy-protected DVDs in a standalone DVD player or in your computer's DVD drive, as long as your computer's software is up to date. These DVDs will play the same as DVDs that are not copy protected
Press the "Eject" button on your DVD player to open the DVD tray. Set the DVD into the tray, and push the "Eject" button to close the tray. Press the "Play" button on your DVD player, and the DVD will play. b> On a DVD Drive on a Computer Press the "Eject" button on your DVD drive to eject the DVD tray. Set the DVD into the DVD drive, and push the tray in to close it. Click the "Start" tab on your computer's home screen to open the "Start" menu. Click on "My Computer" to open it. Click on the DVD drive to open the DVD. Click on "Autoplay" to play the DVD.
Compaq Computers... | Answered on Jan 06, 2020
Google
make model manual
They are all online. It _may_ be an eject button
Replace the CMOS (Complementary Metal-Oxide Semiconductor) battery to ... Turn off and unplug the netbook before replacing the battery. ... Press both orange eject buttons simultaneously, and use a spudger to pry off the back case. .... Tablet · Phone · Laptop · Repairable Products · E-waste · Recycling · Manufacturing ..
Compaq Computers... | Answered on Dec 26, 2019
Check this:
http://diy-ksoft.com/arduino/578-28-inch-tft-lcd-touch-screen-module-uno-expansion-board-for-arduino.html?search_query=LCD+arduino&results=114
There are a lot of touchscreens for arduino. Also if you want to keep it firmware compatible with what you have, you need to know the model and the interface type for it to get a new one that yill match yours.
Without further details is not possible to help you more....
Regards,
L. Coelho
Compaq Computers... | Answered on Dec 20, 2019
You stated an issue about playing/viewing AVI files on your computer?
I would suggest to go ahead and download an AVI file converter(w/c you can search via google or download via Filehippo.com)or get an AVI viewer/Player
(e.g. VLC etc./can also be searched/downloaded via gooogle.com or FileHippo.com)
Hope This Helps.
Thanks,
FixerDelta
Compaq Computers... | Answered on Nov 20, 2019
Compaq iPAQ H3650 Pocket PC Logo
18 questions posted
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Toby Lee
Toby Lee
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
iPAQ Compaq
  • iPAQ Compaq
Most Popular Question
download compaq ipaq 3630 user manual
  • Computers & Internet
