20 Most Recent
Worx Versacut Mini Circular Saw Questions & Answers
Circular saw spinning but not cutting wood
Does the blade actually stop when you try to cut or does it spin but not cut. If it is stopping, and the motor is still running then I am afraid you have stripped gears and will need anew armature and spindle gear (sometimes complete with spindle, sometimes a press fit with a woodruff key to locate it). If the motor is stalling then it would suggest that the field coil is faulty, but you would notice excessive sparking from one brush if this was the case. if you get major sparking from both brushes then the armature is probably faulty, or if you are lucky it could just be brushes wearing low and not making a constant contact. If the blade is spinning and not slowing when you try to cut I would think it is either blunt or mounted the wrong way round.
Saw stops when i start cutting 1/2 plywood.
If it actually binds and stops the motor...... it sounds like the motor is bad, the bearings are bad, or the blade is on backwards. If the motor keeps spinning, but the blade stops then the gears are bad or the blade bolt is not tight.
Clean grease off terracotta tiles
There are a couple of things you could try. I recently came across a specific grout/tile cleaner that works well. You can buy it online. It is a type of cream that you spread over the grease and leave for a while. After it has set, you can use a toothbrush (for best results) to scrub off the soap and grease. Otherwise, you can try magic eraser. Those can be used on tiles and get off a lot. Tiles make up such a great aspect of the house, I hope you can clean them up.
Elisa Jed '
http://www.herrmanntiles.net.au
12/2/2023 11:11:55 AM •
Saws
Answered
on Dec 02, 2023
