20 Most Recent
Baumatic B187 Electric Single Oven Questions & Answers
Manual
Hey there,
You can find a manual on Baumatic's website, at this direct address: http://82.208.58.112/cmd/files/usermanuals-uk/b187.pdf
Cleaning error E1 F5
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
BAUMATIC OVENS BO7C wiring schematics
the fastest way to get access to the manual would be to call the company and ask them to email it to you. Then you can print it out on your end if you wish.
Thank you.
