20 Most Recent
Baumatic B180SS And B60SS (Bundle) Electric Single Oven Questions & Answers
Recently moved into a new house and the oven's
First, call a master who understands ovens. Maybe he can fix it. You should not try to repair it yourself, as it is likely to make it worse. If this does not help, then it will be easier to buy a new oven already. In this way, many problems can be avoided. To be honest, I have never encountered problems with household appliances after moving to new homes. I usually use services that provide a full home inspection before buying it.
https://www.thinspect.com.au/ is a good example. I hope you can solve your problem. But still, I highly recommend that you just buy a new oven, so you can save a lot of time.
Inner glass has fallen out
Have an appliance repairman check if the oven is still under warranty and if any recalls on the door are in force.
Baumatic b180 oven
The oven cabinet is likely built for several different models, which means that the case could have been built with an extra hole or two that aren't used on your model. This a normal manufacturing technique for mass-product factories.
I see from the Baumatic website that several of their models do use a meat thermometer probe, but even if you bought a probe you couldn't use it your oven. Your model doesn't have the correct circuit board and control panel that the oven needs to use the probe.
In any case, if you need to order parts from the manufacturer or would like a downloadable Owners Manual for your model, they are available at this website link:
http://www.baumatic.co.uk/products/discontinued-models/builtinovens/B185SS-B
Hope that helps! ;)
No heat in oven
the element may be open circuit, test it by a continuity test. the actual element is inside the metal outer surrounded by a ceramic compound -you will not be able to see any breaks hence the electrical test.
Baumatic B180ss Electric oven problem
It sounds like the overheat safety stat is cutting the oven off.
This is prevent the oven overheating and catching fire.
They can go faulty and operate prematurely, causing the prob u are experiencing.
If it is built in , make sure it has adequate ventilation, as this can cause the prob.
Also check to see if it has an external cooling fan fitted, these can fail, and again cause the prob.
They are usually fitted under the top cover of the oven, and designed to keep the oven cool.
It should come on shortly after turning the oven on
These things are the most likely cause of the prob.
plz rate my solution.
Thanks.
BAUMATIC OVENS BO7C wiring schematics
the fastest way to get access to the manual would be to call the company and ask them to email it to you. Then you can print it out on your end if you wish.
Thank you.
