20 Most Recent
Compaq Presario 1200,1600, Series CD ROM(297657-001) (EP8RDA3G) Motherboard Questions & Answers
Compaq presario C700 continous beep when starting up
Potential Hard Drive failure, (Hard drive s.m.a.r.t. beep) or if MB beep it's chassis intrusion..
1. Remove battery + disconnect power
2. Hold down power button for 20 seconds
3. connect power only (no battery)
4. Turn computer on.
If the beeps stopped.. get a new battery, if the beeps continue..
ABANDON SHIP!
I need to know how to access the hard drive on my
Good day jar
Well firstly, i wanna know if your trying to install windows? if so then a normal windows disc is not gonna help you, there is a option in you bois which you have to unset possible it is called visualize or sumthing,
then get a Dell or acer pre intaller oem windows disc, cos there is a lock on the hard drive which you cant remove with a normal windows os disc, or yust in stall vista
sure it will help
email me if you have any other problems
[email protected]
thanx bertus
Problem with System booting Compaq Presario 12XL500
Check your memory sticks to make sure that they are full inserted and did not come loose. Check the power from power supply going to HD. Make sure it is getting power. You can also remove your motherboard and test components with an ohmmeter to see if there are any burned out components which is very possible. Have seen bad boards and bad power supply's both cause your problem
Compaq presario v3122tu laptop motherboard cd not getting anywhere
hi,
Post the laptop model no and make so I can send you all the detail. you can download and install it. change the harddisk with greater space there shouldn't be any challenge on it. But you can't upgraid your cpu with duo core cpu.
anyway you post the detail of you model, I'll post the detail answer.
Thanks
Arun
