20 Most Recent
Dewalt 3/8" Heavy-duty Vsr Drills - Dwd115k Questions & Answers
Dewalt keyless chuck stuck
nope... make sure there isn't a screw in the center of it... look inside... then take a 3/8th's hex key, tighten the chuck down on the short end of it and smack the long end of it with a hammer. the chuck will unscrew... go get a new one
Dewalt D55168 225 PSI Air compressor: What are the preset pressure limits for this model? Is it actually 225 - 180?
https://www.manualslib.com/manual/494085/Dewalt-D55168.htmlSpecifncationsMODEL D55168WEIGHT 88 Ibs. (39.92 kg)HEIGHT 41.75" (1060.5mm)WIDTH 19.0" (4826 mm)LENGTH 21.25 (539.8 ram)AIRTANK CAPACITY (GALLONS) 15 Gallon (56.8 fiters)APPROX CUT-_N PRESSURE 160 PSI (1103.2 kPa)APPROX. CUT-OUT PRESSURE 200 PSI (1379.0 kPa)SCFM @ 90 PSI (620.5 kPa_ 5._cant get fixya comment to work so will edit here...The 200/160 are the typical DS55168 settings from factory and meet the 90 psi @ 5.4 cfm rating.Pressures can be adjusted to a MAXIMUM 225/185 with a resulting lower cfm rate.I'm not familiar with "type 9". Likely nothing special just different setting from factory?
