20 Most Recent
Compaq iPAQ Home Internet Appliance IA-1 (178358-001) PC Desktop Questions & Answers
Installing the compaq home internet appliance
does the appliance have a dchp ip address option or auto ip address option. The IP address is used by the wireless network to identify each computer device in your house.
In your wireless router there will be a dhcp server that will lease out ip addresses to devices automatically.
the ip address would be 10.0.0.1 for your router or 192.168.0.1 usually most used ip addresses .
A subnet mask is usually 255.255.255.0 which is also needed.
Go to your desktop computer and go to command prompt . Google your version of windows and command prompt to work out how to do this.
then type in ipconfig
press enter key
note the default gateway address and the desktop's ip address
you may need to enter the default gateway ip address into the fridge also.
if the desktop was 10.0.0.2 subnet mask 255.255.255.0
then make the fridge if manually have to set it
10.0.0.254 subnet mask 255.255.255.0
or 192.168.0.254 subnet mask 255.255.255.0 if it is 192.168.0.2
the first three numbers are called the network address eg 192.168.0
10.0.0
the last number 1 - 254 are individual address part
192.168.0.1 {router uses this 1 usually } to 192.168.0.254
IPAQ Internet Appliance
You inquire on your nearest Internet Service Provider (ISP) for a DSL plan. DSL provides a bandwidth 3 to 4 times of the dial up.
How do you reset the compaq I-A internet appliance
when u power up the computer press F8 key then enter in enable vga mode.then change screen resolution to 1024*768 then aply and ok then resatrt then it issue is solved.
If u can not able to see that menu then u need recovery disk.
MSN companion support
Unfortunately, since HP purchased the Compaq brand, it is very difficult to find contact numbers for compaq, You may need to search the compaq / HP websites for contact numbers, and ask to be transfered to one of thier representitives.
Compaq was bought with msn companion service required
This is where you should be in contact with Comcast Tech Support 1-888 262-6300.
The INSTALL tech should have had you on-line before he left.
You need to conect your TV/Computer Cable to a Cable modem and a CAT 5 cable to your NIC (Network Interface Card)
All the lights on the modem should be on except the TEST light and the DATA light should be blinking.
You may have OLD drivers for the Cable modem, download those from another computer from the modem MFG.
Nothing else is required.
I brought a used campaq IA-1 and cant delete old users and add me
there is only one way to restore this system, you will have to take the hard drive out and hook it up into another desktop and install windows 98/me or 2k to it and then put the drive back into the compaq more than likely you will have to download drivers for it as well
I need help with my compaq computer
Could be you tried to upgrade the current version you have why dont you repair the current version if you are using XP and the message will dissapear
