20 Most Recent Compaq D70045-236 Tablet PC Questions & Answers
2answers
2 Compaq TC 1100 - neither boots
Try first to clean you memory using the eraser and put it again. Then u can use flashdrive in installing your windows. It can be that your cd/dvd drive is the problem. Hope this can help.
5/1/2017 1:55:52 AM • Compaq... • Answered on May 01, 2017
Have a proscan tabket and the keyboard not
Keyboard defective. Replacement should be done. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/
6/14/2014 9:50:28 AM • Compaq... • Answered on Jun 14, 2014
6answers
Forgot password
Forgot Windows login password? Take it easy, you can unlock forgotten password with Windows 7 Password Recovery Tool easily!
4/9/2013 7:31:43 AM • Compaq... • Answered on Apr 09, 2013
2answers
"Operating System Not Found" in Compaq Tablet PC TC 1000
That means it is unable to see your harddrive. Unlike a tower computer a laptops harddrive plugs straight into the motherboard this cannot be a cable fault.
Either the harddrive has died or the motherboards drive controller has gane bad.
You will need to seek profesional help to deal with this, the only thing you can do your self would be to swap the harddrive with another and see if you get a Windows stop message, your machine would not be able to start the Windows of another machine because of hardware differences, but if you got a Windows error message at least it would tell you if your harddrive was dead or not.
8/10/2010 10:22:43 PM • Compaq... • Answered on Aug 10, 2010
My Compaq tablet keeps freezing at random
I'd take it apart & clean the cpu heatsink & fan & also make sure the fan works. Then if that's not it,check the hard drive.
5/4/2010 3:06:51 PM • Compaq... • Answered on May 04, 2010
This is voice password and voice recorder
IF your voice is not being recognised , U can access to your system by installing another operating system in any other part of your computer through BIOS.
For this it is necessary that your BIOS must not be passward protected.
Once u get access to your system, u can make desired changes in settings to get rid of voice passward.
4/9/2010 2:48:21 PM • Compaq... • Answered on Apr 09, 2010
Were is the ram situated
The Compaq Tablet PC TC1000? (Marketing Part Number D 70045-236)
Turn the laptop over, you're looking at the bottom. Battery Compartment is to the Right.
To the left of the battery compartment is the Memory Compartment. (The parting line for the memory compartment door, starts to the left of the battery release button)
The Memory Compartment is rectangular in shape. The right lower corner has a half U shaped cutout. (Next to the battery release button)
At the top of this panel, or door, are two Philips head screws. These are removed. The panel is then lifted up at the side the screws are on, SLIGHTLY, then slid forward. (Forward. Away from you)
(There are two plastic tabs at the end towards you. They slide into the body of the laptop, and if the panel is lifted Straight up, these small plastic tabs could break off)
This is HP Support, and the download page for Manuals, for the Compaq TC1000
(HP and Compaq are one, and the same entity now)
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=307008
I would like you to download the Hardware Guide for this tablet PC. It explains about the hardware, and also shows how to install ram memory.
(Copy and paste the above link to your address bar, press the Enter key)
Under the - General Reference - section heading.
Click on - Compaq Table PC TC1000
Series Hardware Guide
(Second one down)
This is a PDF file. Your computer has Adobe Reader on it, which uses PDF files.
I advise letting it download all the way before looking through it, or you may break the download connection.
Page 128 starts with telling you how much is the Maximum Amount of ram memory.
(512MB)
Tells you that there is only 1 Ram slot.
The next page tells, and shows you how to open the Memory Compartment door, then details how to remove,and install ram memory.
11/22/2009 8:06:28 PM • Compaq... • Answered on Nov 22, 2009
The pc will not switch on - when using the
unplug the battery and power up the pc with just the cord. if it boots battery is probably bad.
11/1/2009 8:06:16 PM • Compaq... • Answered on Nov 01, 2009
Will not boot up
the same thing happened to me ...i got a virus i had to do complicated things things on safe mode on the command promt.
9/11/2009 3:08:43 AM • Compaq... • Answered on Sep 11, 2009
2answers
Key board and mouse is locked
Try plugging an external keyboard and/or mouse.
See if that works.
1/29/2009 6:14:13 PM • Compaq... • Answered on Jan 29, 2009
Compaq CT101 Tablet. Looking for repair manual for it.
Unfortunately a Service Repair Manual doesn't appear to exist. Apart from replacing batteries, the rest is one motherboard and a screen. https://www.google.com/search?q=compaq+ct101+tablet+service+manual ..
5/6/2022 1:30:59 AM • Compaq Tablets &... • Answered on May 06, 2022
How do you fix a power- on password on a HP Compaq
power on password poblem
6/10/2011 10:47:01 AM • Compaq Tablets &... • Answered on Jun 10, 2011
How to turn on the webcome on compaq laptop
It usually already on. You just need an application that supports webcams. Try Skype or Chatroulette.
3/24/2011 6:52:40 AM • Compaq Tablets &... • Answered on Mar 24, 2011
I want to start inter net from my laptop what to
Hello Punitrava, Hi, you can connect to the internet several ways, here are the common ones. 1. Via a free WIFI hotspot, find a WIFI area like in malls or coffee shops and enable you WIFI connection on your laptop. after enable the laptop detects the wireless connection and simply connect. 2. Via a USB modem, inquire about this on your wireless telephone company. 3. Via the Local Area Network like computer shops, insert any available LAN cable on your LAN connection, you need to consult the LAN administrator. 5. Via a DSL connection, just plug in the LAN cable from a DSL to your laptop. you need a DSL/internet account from your telephone company.
1/8/2011 5:06:10 AM • Compaq Tablets &... • Answered on Jan 08, 2011
Where i can bay motherboard
if you buy tablet PC i think to the website http://www.itabletpcshop.com
10/13/2010 4:24:51 PM • Compaq Tablets &... • Answered on Oct 13, 2010
Laptop wont charge
Orange means it's charging or connected vs. green means fully charged.
At least that's the way my battery charger is on my kodak camera.
7/28/2010 8:50:18 AM • Compaq Tablets &... • Answered on Jul 28, 2010
Compaq D70045-236 Tablet PC Logo
Popular Tags
18 questions posted
Top Compaq Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Compaq Tablets & eReaders
Most Popular Question
forgot password
  • Tablets & eReaders
