20 Most Recent Dewalt 12v Max - 20v Max Li-ion Battery Charger Dcb101 Questions & Answers
Unless it is rated for 220-50/110-60, you will need the converter. Besides the 110V US plugs won't plug into the 200V UK outlets.
Dewalt 12v Max -... | Answered on Apr 14, 2015
Can't say for certain, but there are specific 110V and 220V versions of DCB101.
None are labelled 90-220VAC as would be normal for universal voltage equipment.
If you operate 110V equipment on 220V then you will most likely damage it with overvoltage.
If you operate 220V equipment on 110V then you will most likely damage it in over current or have it simply not work.
It is possible that the charger is universal, just not labelled as such.
Send DeWalt an email.
Dewalt 12v Max -... | Answered on Mar 29, 2015
High Performance Current Mode Controller doesn't work for you in the charger. According to the link, scheme.http://kazus.ru/forums/attachment.php?attachmentid=51161&d=1377505983
Dewalt 12v Max -... | Answered on Sep 18, 2014
It might be one of the following: 1. Voltage changeover selector switch has blown - check if the power is still there before it enters the switch and still there after it leaves. 2. Breaker has failed on that leg - test before and after to see if working correctly 3. The plug socket has failed - Look for burn marks where wiring enters. 3. There is a fault in the alternator - see 2nd video down on this page for testing:https://www.generatorguru.com/help-me-fix-my-generator-repair-advice/ Hope this helps you. If you need more advise please contact us on our website www.generatorguru.com. We are always happy to help.
Kind regards The Generator Guru Team www.GeneratorGuru.com gg_pic5black_adwords_1200x1200small-u42hrofub43isob1vkbjdq4v-5-14.jpg
Generator Guru
Dewalt... | Answered on Oct 29, 2018
It should be used on a 20 amp circuit. the 15 amp is the maximum your circuit will deliver. on startup it may exceed the limit. also your circuit may or may not deliver the power for a sustained time. do not use extension cord small than 12 gauge
Dewalt... | Answered on Aug 06, 2018
Remove spark plug. Pour a small amount of a lubricant like Marvel Mystery Oil in and allow to soak for a day or two. Repeat this process at least two times. Then try to turn the engine over slowly by hand. Do not use the pull rope or starter. You need to use a wrench, pry bar, etc. You may have to remove the engines cover to access the flywheel to turn it.
Dewalt... | Answered on Oct 07, 2016
would suspect you need to go to the Dewalt website to do that
Dewalt... | Answered on Mar 06, 2016
You might have a thermal issue with the ignition coil shutting down after it gets warm. Happens.
Dewalt... | Answered on Sep 25, 2015
It's your carburetor. You'll have to clean it out, rebuild it, or buy a new one. The float pin is getting stuck so it's either the float or dirt inside. Make sure you turn the gas off after each use of your generator or it will eventually happen if there's dirt in the tank. Don't forget to change out the oil before you start it again or you'll have fireworks.
Dewalt... | Answered on May 28, 2015
Dewalt 12v Max - 20v Max Li-ion Battery Charger Dcb101 Logo
12 questions posted
Top Dewalt Electrical Supplies Experts
Sheldon Dedek
Jay Plesset
John Trevino
Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Dewalt Electrical Supplies
Most Popular Question
use charger 220 in uk
  • Electrical Supplies
