20 Most Recent Armstrong ASTRO-30B CIRCULATOR PUMP Questions & Answers
Gee, that's a toughie, Bob.....
To take performance-enhancing drugs,
or not to take performance-enhancing drugs.?
.........A* to me
Armstrong... | Answered on Mar 14, 2018
Google him
Armstrong... | Answered on Oct 28, 2017
That unit is not even listed on Armstrong website.
Armstrong... | Answered on Oct 05, 2015
Check power to the pump.
Armstrong... | Answered on Oct 03, 2013
The most common problem with these circulators is that the stator gets stuck and does not turn.
Sometimes you can take out the four bolts on the corners and pull the motor off. Get the stator freed up again and it will work. Make sure to turn the water off before dissassembling the pump. Hopefully you have valves do you can isolate the pump.
Also check that the impeller has not broken off the end of the shaft, that also happens sometimes.
You can check the cap. with an OHM meter by switching the terminals with the test leads and the resistance should count down to zero with each switch of the leads on the terminals...if not it is bad, but replacement of the cap. may not fix the pump usually it is a secondary failure...
If you can't get the pump ot work after taking it apart and making sure it turns freely then I would replace the pump.
Heatman101
Armstrong... | Answered on Dec 29, 2009
A line voltage thermostat is just like any other type of switch, except that it's controlled by temperature.
Just wire the 120vac to the pump, but interrupt the hot (black) wire with the thermostat.
Let me know if you need more help.
Armstrong... | Answered on Oct 30, 2009
I bled air from the rads attached to the system and now the noise is gone from my circulator pump
Armstrong... | Answered on Dec 04, 2008
Armstrong ASTRO-30B CIRCULATOR PUMP Logo
2 questions posted
Top Armstrong Plumbing Experts
Paul Carew
Gil Shultz
Are you an Armstrong Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Armstrong Plumbing
  • Armstrong Plumbing
Most Popular Question
furnace shuts off
  • Plumbing
