20 Most Recent
Makita HR4041C 1-9/16" Spline Hammer Questions & Answers
Makita HR4041C rotary hammer drill
There is no tension to adjust on the Makita HR4041C rotary hammer drill. If you are not getting the hammer action you think you should be it's possible the o-rings on the piston are damaged or not lubricated or the striker is stuck or not lubricated enough to work properly. If you're having problems with the bit turning, there are several gears that turn the bit that could be slipping or are stripped. If you need a manual or brakedown of the tool, one is available on
www.makitatools.com. The insides of rotary hammers are fairly complicated so be carefull of what goes where if you decide to take the tool apart to check for internal problems.
Why does my new Makita dbn600 brad gun will not go deep enough with the rubber protector on.
Makita and Dewalt can being used with similar nails of other brands ? some sellers will you do believe but i can say by marketing technical updates Makita and Dewalt have very rare strict tolerance on dimensions but only original nails will and must working without problems , and 2nd choice nails have allways an other thickness or other kind of bonding they are made of. , use only the nails of the brand you working with if you have or MAKITA or DEWALT use the nails for the brand. otherwise the nailbrads will not slide smoothly its very critical made the last years more and more models of the brand have restrictions and get very fast troubles with cheap homebrands of hardware store parties. USE ONLY ORIGINAL delivered by the new Makita and Dewalt tools. otherwise if not working read the user manual if no succes go for warranty if its not work correct .
Bostich n66 nailer
Does the nailer fire but just not drive a nail, or does it not fire at all? If it's the first situation, it's a magazine feed issue. I had one of those and it started doing something very similar. The magazine spring had gotten dirty from use which didn't allow it to function properly. (Carefully) disassemble the magazine and clean the spring. Automotive brake cleaner works pretty good for that. Spray the guides with a dry lubricant then reassemble. If it's the second situation, I can't help you there.
