20 Most Recent Casio LK30 Note Lighted Keyboard Questions & Answers
My sister has the casio LK 30 for her special
If it's blown a regulator in the keyboard you may be lucky that that's all that's gone.... If unlucky it could have rippled through & taken out a lot of the electronics. (aka a right off) A decent repair shop should be able to take a look & give you a price to sort it.....
2/1/2018 12:03:15 PM • Casio LK30 Note... • Answered on Feb 01, 2018
Casio lk-33 does not work with external power
I once had this problem with another Casio synth.I hadn't the power adapter ant I tried with an other one, with the same specifications : the synth was apparently powered but it didn't work.I finally understood that it was a problem of polarity (+/-). You may just have to cut the cable and resold it inverted.Hope it could help!
4/26/2013 10:33:37 AM • Casio LK30 Note... • Answered on Apr 26, 2013
2answers
Casio WK 1600 : Sustained keys
Remove all power sources for at least 2 minutes. That means removing the batteries and power cord completely from the K board. Then try again. If that doesn't do it, it'll be time for a service visit...accordianman
11/5/2011 1:12:16 AM • Casio LK30 Note... • Answered on Nov 05, 2011
2answers
No instruction manual
Yes I have one which I can photocopy for you if you are still looking. I appear to have lost my Power Adaptor and would appreciate knowing any Name or reference on yours if you have one.
My e_mail address is [email protected] if you care to contact me.
Thanks.
Duggie
4/16/2011 10:06:49 PM • Casio LK30 Note... • Answered on Apr 16, 2011
0answers
0answers
Need replacement key set for Casio LK-110
You would need to call casio for such parts or go to a part store which by googling it you can find the parts for this unit.
3/16/2010 3:10:36 PM • Casio LK30 Note... • Answered on Mar 16, 2010
I have a problem with my LCD,the keyboard id
See the answer to: http://www.fixya.com/PostAnswer.aspx?thid=3726424&prdid=360392
since your question is exactly the same as asked in that question.
12/27/2009 2:35:56 PM • Casio LK30 Note... • Answered on Dec 27, 2009
7 of the keys on the upper end of my privia px-100
It may due to faulty circuit board of the keyboard. Check for warranty and ask the vendor to replace the keyboard.
12/15/2009 7:40:52 PM • Casio LK30 Note... • Answered on Dec 15, 2009
2answers
I need a manual for my casio lk30 keyboard
I hope this link is what you are looking for:
http://www.usersmanualguide.com/manuals/casio/LK-30_LK-33.pdf
9/21/2009 5:38:36 PM • Casio LK30 Note... • Answered on Sep 21, 2009
Casio 1600 sustain pedal problem
Not if its like mine, its a completecircuit vs.incomplete circuit problems.
I had the exact same problem with my Casio keyboard and a Yamaha sustain pedal I bought.
I'm not an electrical genius, but I was able to get it to work by opening it up and doing a little modification. Of course I first just tried switching the white wire with the black one but that didn't change anything at all when I tried it. It turns out the Casio wants the circuit completed to sustain, and broken for no sustain, which is the opposite of what the Yamaha pedal does.
I opened it up and mine had three three flat metal strips let's call them Top, Middle and Bottom. The Middle and Bottom ones were joined together on the right side, and the Middle and Top ones were touching on the left side when the pedal was not pressed. These seperated when the pedal was pressed, thereby breaking the circuit because the wires were on the top plate and on the joined Middle/Bottom plate.
So to flip it I:
1. Unsoldered the Bottom wire
2. Cut apart the Bottom and Middle plates on the right.
3. Bent the Middle plate on the right to touch the Top plate instead and soldered those together.
4. Soldered the Bottom wire back on.
That's it! Once I figured it out, it took only a few minutes to fix.
Paul
8/15/2009 11:42:05 PM • Casio LK30 Note... • Answered on Aug 15, 2009
I have a ctk-671 and the power cord has been
Sir, This jack installs on most Casio keyboards to replace broken ones-a common problem. Often the broken jacks have the center connection pin ripped out or loose when the power cord cable has been pulled with a vacuum cleaner or yanked by a pet or child.
A technician is recommended to replace this part on your Casio instrument.
check with site www.keyboardstoday.com
Thanks Good luck
8/14/2009 4:35:00 AM • Casio LK30 Note... • Answered on Aug 14, 2009
2answers
No owners instruction book for LK-33 Casio portable lighted keybo
I was also looking for the manual on-line which an e-bay seller told me was available. Not from Casio, but someone was nice enough to scan in a manual at http://www.usersmanualguide.com/casio/musical_instruments/lk-30. It is in PDF format, so you will need to download it and view it with Acrobat reader or similar. Not the greatest quality as it is just a copy, but certainly readable.
6/21/2009 3:19:36 AM • Casio LK30 Note... • Answered on Jun 21, 2009
I need a Casio LK-30 AC Adapter
Check out this link:
http://www.zzounds.com/item--CASAD5
It looks like the right one to me. I am ordering one today for our keyboard.
10/8/2008 2:00:34 PM • Casio LK30 Note... • Answered on Oct 08, 2008
CT731 keyboard wont read floppy
try getting a cleaning floppy disk  (the head might be dirty)
hope this helps
9/5/2008 2:24:58 AM • Casio LK30 Note... • Answered on Sep 05, 2008
Music Logo
Popular Tags
34 questions posted
Top Casio Music Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Casio Music Expert? Answer questions, earn points and help others
View Most Popular
Casio Music
  • Casio Music
Most Popular Question
casio lk 33 not work external power
  • Music
