20 Most Recent
Canon CanoScan LiDE 500F Flatbed Scanner Questions & Answers
There is not enough free
Hi ,
It seems obvious that you should free some space on your hdd by deleting the excessive amount of useless files .
1° solution 1 :Clic on " computer" or " my computer " , right clic on C ( primary HDD ) and go to Properties \ Disc clean up and follow instructions .
2° solution 2° :If your Hdd is partitionned C and D , you can increase space on C wit Partition Wizard from
http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html
Hope this can help .
Thanks for visiting FixYa .
Regards .
Why can I not run my Lide 500F scanner with a Windows 7 PC?
I have a cannon flat scanner 2000 & I came across this once before, I uninstalled all the cannon drivers then re-started the PC & next instead of using the Cannon drivers, I used Microsoft's Drivers & it's worked fine ever since.
I hope this works for yourself as well. Best Wishes. Malcolm.
Canoscan LiDE 500f Driver for linux ubuntu
Stelios: there is no "linux" choice on the link you provide. thumbs down, looks like you haven't even tried dwonloading it, without mention to getting the device to work with the "driver" you suggest.
Install canoscan LIDE 500F
Hello you can download the driver here:http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide_500f?selectedName=DriversAndSoftwareIts free and remember to select your current operating system 32 or 64 bit.Good luck
Scanner not working
hrm, i found out how to solve the issue. remove the film and do a calibration for the frame, now the scanner starts to calibrate, after a 30sec the program told me to put the film in and scan.
tadaaaaa..
Driver for lide 500f for ubuntu/linux?
From
this link select linux as your op. system and the desired language and download the drivers you asked for.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.Thanks and regards
Please kindly rate this solution
Stelios
direct
fixya link: http://www.fixya.com/users/technical114
I have been using it
Hi
Scanning require disk space in you computer. Try to remove some clean up or remove some document files in your hard drive to free some space. Check also your C and D drive jf how much disk space it available.
