20 Most Recent
Canon DR-7580 Questions & Answers
Bar Code Used as Document Name
It's not really an issue with the scanner. The scanner will pick up the image and convert it to whatever you want, but your backend software is what you'll need to mess with for this. Any form recognition software will work (Form Storm, ABBYY FormReader, etc.)
Capture barcode at scanner Canon Dr 9080C
You will need to purchase the CD "Canon Barcode Module III" and install it on your computer: Mfg. Part: 1922B001
Then you can select it in Canon's document scanning software/Capture Perfect.
Scan-R-Store
SAYS STAPLE DETECTED BUT NO STAPLE
Try cleaning the staple detection sensors in the machine. Most of the time if you blow air gently into the machine to clear dust from the sensors.
STAPLE DETECTED
Try turning off the Staple detection option in the settings.
Installer captureperfect
Not sure as to what you are asking as there is not a question here. As you asking about locating an installer application for Capture Perfect??
Scanning half a page
You will need to check your page settings. As each program is different, the page setup will generally stay the same. It will also change if you are scanning at 0, 90, 180, or 270 degrees as well.
How to replace sensor in DR7580?
Which sensor do you need to replace? These machines have several sensors throught the machine that assist with lifting the tray, watching for staples, and even double feed detection.
Line down middle of paper
Sounds like you have a scratched lens. If you have another unit, try replacing the lens from that one. If you do not, you will need to replace the complete unit or see if you can find one on Ebay.
Won't lift
Check the roller cover. If the roller cover is not firmly closed it will cause a feed error.
I opened and firmly closed the roller cover until I hear it click.
After that it lift the tray to scan..
