20 Most Recent
Canon DR-2050C Path-Through Scanner Questions & Answers
Can I share my Scanner on a Local Area Network?
no, but what you can do is hook it up the computer and share that file to the network. for example, if you scan it, you'll have to use that computer to load the images to that file. and all the other computers on the network can see that file. you can do that. let me know if you need more info.
I have canon DR-2010C scanner
Question canon DR-2010C scanner which gives error after some times.my
system is vista.the error is "The device could not be locked. Check to
see that another application isn't using the device -4630".Answer :- change USB cable which is connect with scanner to PC or laptop definitely it will resolve.By:- shyam
[email protected] 9210845186
Scanner wont start
By "start", do you mean power up or do you mean it won't begin to scan?
No image scanned
Check your brightness settings. Try Automatic settings if available.
S. Mohan
