20 Most Recent Canon PIXMA MP780 All-In-One InkJet Printer Questions & Answers
I think you are seeing "ERROR 5100: Cartridge Jammed", right?. Here is the most likely solution to this issue with your printer. The following procedure comes directly form Canon
ERROR LCD: CARTRIDGE JAMMED
1. Press ON/OFF switch to reset the multifunction device 2. Removing obstructions, foreign objects and paper jams MP750 / MP780 3. Reseat MP750 / MP780 print head 4. The MP780 may require repair
Canon PIXMA... | Answered on Apr 17, 2019
Your printer software is doing image detection.
You need to adjust setting on scan so it scans page and image detection is off.
Please dont forget to vote if you liked my answer
thanks
Canon PIXMA... | Answered on Mar 16, 2019
Hello thanks for asking, i notice you you really did some valid but the problem still exist. Please check the settings for your printer to make sure they are correct, and please uninstall and reinstall the drivers for the printer once again and please make sure its the right drivers for your printer.
Canon PIXMA... | Answered on Dec 01, 2018
How To Resolve Setup Issues Of Printer? Call 1-800-956-0247
Are you looking for expert help for set up problems of printer? Is your printer set up wrongly? Don't worry more, we are a complete technical guide at toll free Printer Support Number 1-800-956-0247 to provide the best troubleshooting instructions for online printer users in very reasonable charges. Our tech support engineers know every technical aspect for setting up printer in the right ways. Our highly knowledgeable and rich experienced printer experts are very smart for solving set up errors of printer simply. Our printer technical support phone number is very helpful number that provides the best solutions for any issue.
Corporate Office:-
1073 Rosedale Road,
Valley Stream, NY 11581, USA
USA Phone Number:- (800)-956-0247
Email:- support@printerfixit365.com
http://www.printerfixit365.com/
Canon PIXMA... | Answered on Mar 23, 2018
Hi if the problem persists after deep cleaning the print head maybe Is defective. Search in youtube a tutorial to perform a different deep clean to the print head
Canon PIXMA... | Answered on Feb 19, 2018
Make certain you have the current updated drivers for the printer. Check to see if the printer is recognized as one of the devices active and available. If its wireless, be certain the communication is both ways. Do a printer test of the Wireless transmission phase. If you connect directly by Cat5/6 cable with Ethernet, check drivers. Check cables. Check for a positive connection on both ports, Computer and Printer. Make certain the printer listed is the Main Printer when you do a setup.
Canon PIXMA... | Answered on Feb 08, 2018
the black is plugged in the printhead. take it out, and to the sink. run hot water thru the head. rinse it thoroughly. even put the nozzles up to the sink nozzle and force water thru it. when it decided to unplug you will get a bunch of black ink for a second or two. then take the head and shake it out and if possible blow it out with compressed air. get it dry then take a pencil eraser to the contact points on the back of the printhead to clean them. reinstall your printer and let it cycle to charge the printhead. try to print. if not good results try one more clean and if still no black, go back to the sindk and try again. repeat this a couple of times, if it doesn't work, let it sit in really hot water for a while then try to flush it out again. make sure it is dry when you put it back into the printer. try to print again. do use good inks to do this. empty ones won't work.
Canon PIXMA... | Answered on Jan 13, 2018
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Kevin download drivers and software to suit HERE - please rate
In case I stuffed the other link link
Canon PIXMA... | Answered on Jan 03, 2018
I cleaned my print heads 7 times before it all cleared up. Another possibility is there may have been a piece of clear paper or sticker or something on the replacement cartridge - take the cartridge next to it out and compare the two to make sure they look the same.
Canon PIXMA... | Answered on Dec 02, 2017
Only thing I can suggest is contact Canon thru their website.
Hello!
Please check the "Rplacing an ink tank" part of the manual. Hope it will help you.
https://manualsbrain.com/en/manuals/1796179/?page=45
Canon PIXMA... | Answered on Oct 24, 2017
Try cleaning the heads and check print head allignment on the printer, this can usually be done through the printer software or your pc settings
Canon PIXMA... | Answered on Aug 21, 2017
Canon PIXMA MP780 All-In-One InkJet Printer Logo
1,572 questions posted
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
need installation software
  • Office Equipment & Supplies
