20 Most Recent
Canon PIXMA iP90 Mobile Printer Questions & Answers
Canon ip90 printer
The printer should be on,remove the paper from the printer(if there is any),press and hold the down arrow/cancel button, release the button when the power light blinks 3 times ... The printer will rollers will automatically revolce and clear all the jams.. When the power light is green then repeat the same step 3-4 times.. To confirm the paper jam is cleared then feed 8 1/2 * 11 paper in the printer and again press the down arrow button and release the button once the power light bliks for 3 times and then release the button. If the printer feeds properly it confirms the hardware of the printer is fine.
Software issue: Go to printer and faxes in computer and check the icon. If it says.. 0 paper jam then, delete the icon and chcek in the device manager if there is an entry of usb printing support under Universal Serial Bus controller .. if the entry is there then delete it. Insert the printer cd in the computer and unplug and replug the usb cable from the printer. If the setup screen comes up then exit out of it and the printer drivers will get updated. After that tried to print another tets page from the computer. It will definately print. Thank you.
MY CANON IT NOT WORKING IT'S FLASHING 8 TIMES
Hi there you can try.
Following step by step resetting canon Pixma iP90 :
- Before resetting printer canon iP90, start with printer power off.
- Press resume button coincide with power button.
- While pressing power button, release resume button.
- Press resume button 2 times and then release both button
- Green LED indicator will blinking and then stopped blinking.
- When the Power LED lights in green, press resume button 4 times.
- Press power button and the printer power will off. Otherwise off, depress again power button.
- And the turn on the printer again, your printer canon iP90 should be response as normal.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best
: Pineworks
How to replace canon print head printer ip90
After you open the cover and the carriage comes to the center for new ink, you press the resume button for a few seconds and the carriage will go to the printhead changing position. You don't want to ever force the printhead to move. Hope you didn't break something already. Sorry for the stupid help.
How to clean roller
I suspect your ip90 is suffering from the paper feed fault. Has a spring fallen out? Getting it back in is a nightmare in fact other than changing heads on the ip90 everything is a nightmare. In most cases the either the paper feed assy needs changing or the print engine needs replacing. Its not cost effective on the ip90. Think about replacing it.
Canon ip90 will not take paper through the printer
I have had similar problems with Canon and Epson printers. Standard solutions are not earth shaking, but worth a try. Use paper heavier than 20 lb, get a roller cleaner paper from the manufacturer
and run it through to clean the rollers.
