20 Most Recent Canon MultiPASS F60 All-In-One InkJet Printer Questions & Answers
Hi. if your multipass is connected to a computer you can check in the printer monitor status the exact error . Or you can count how many time the error display blinks
Canon MultiPASS... | Answered on May 20, 2017
Download BenQ Multifunctional Driver cm3000
Canon MultiPASS... | Answered on Mar 16, 2013
Part replacement:
- Ink cartridge
- Logic board
Canon MultiPASS... | Answered on Aug 22, 2011
Window 7 operatimg system is the latest on the market so expected not to malfucntion. The situation with the recent computers despite being latest innovations in technology is least compartibiluity with prior systems. Consider that, your computer is the most up to date and should not be interfered with older codes from prior operating systems. You may be attempting to connect an older devices requiring codes on the windows 7. However, so far windows 7 is still getting in to the user explorability phase similar with prior operating systems. What this means is that, the more complaints about the operating systems, programers tend to redesign compartibilty hybrids to the sytem if not changed by a better computer altogether. Keep in mind that, if a computer program is not communicating with windows 7, dont mind to much since your computer is in perfect order. likely, the additional program is malfunctioning because is outdate and likely incompartible upgrade with windows 7. Identify the specific incompartibilty program code to be communicated to the microsoft internet site as malfunction would initiate an alternate code to bridge the condition. Also, join an internet computer programmers blog to lay the problem on the table. They would delibrate to invent sofwares observed about the recent windows 7.
Canon MultiPASS... | Answered on Jan 17, 2011
I've checked and you can't. Canon don not spport Win7 with this printer so you will have to replace it.
You should also check any other periferals you have using the Win7 compatability wizard available from Microsoft.
Canon MultiPASS... | Answered on Aug 03, 2010
1st You download Printer Driver. Canon Multipass Inkjet Printer Driver After this install the Printer driver in the system.
Installation of Printer Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Canon MultiPASS... | Answered on May 13, 2010
Hi there
Just take them out and gave the brass connexions a good clean and put back.
All the best Pineworks
Canon MultiPASS... | Answered on Apr 27, 2010
SYSTEM ERROR 805
Canon MultiPASS... | Answered on Apr 26, 2010
You need to remove the inks and lift out the printhead, check the bottom for any paper scraps, wipe gently on a damp paper towel. If after cleaning you still get partial blue, you will need a new printhead. The part number is stamped on the side of the printhead. Sometimes paper lint and scraps stick to the bottom of the printhead.
Canon MultiPASS... | Answered on Apr 21, 2010
The waste ink absorber may be full, may not. But the message comes up on cannon printers after so many hours of use regardless. Just reset it.
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
Canon MultiPASS... | Answered on Mar 26, 2010
If it has a nozzle cleaning option use that.
If that doesn't work try some of that pink cleaning flush you get with refil kits on the nozzles.
Canon MultiPASS... | Answered on Feb 13, 2010
Maybe it waste ink
This works on the F30, F60, and F80.
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 printers.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Hello hope it work for you
Hi
Canon MultiPASS F60 All-In-One InkJet Printer Logo
123 questions posted
Clive
Clive
old marine
old marine
Ekse
View Most Popular
MultiPASS Canon
  • MultiPASS Canon
Most Popular Question
am trying get canon multipass f60 work
  • Office Equipment & Supplies
