20 Most Recent
Canon imageRUNNER C3220 Printer Questions & Answers
Canon iR C3220 Printer TCP/IP settings
Wow,
I am not sure why or how I just bumped into this question 8 months later....and why no one has answered your question prior. I hope to God some one has helped you or you bumped into it on your own. If not, press additional functions,system settings, network settings, and the rest is obvious.
7/11/2013 1:56:08 PM •
Canon...
Answered
on Jul 11, 2013
Dirty drum
change to thick paper in add function
12/8/2011 6:21:03 PM •
Canon...
Answered
on Dec 08, 2011
Canon iRC 2620 error code E000020-04c0 Any ideas?
The error code E020 refers to a density problem with one of the Drum Units. The sub-code 03b0 refers to one specific Drum Unit, of which
I'm not sure. I believe if you go into service mode and check Density, you'll see each Drum Unit listed there. You are looking for an average Density reading of +-2.5 for the Units. Don't get crazy trying to reach that value, but look to see which one is way off and that may be your culprit. Or maybe one of these other guys may be able to tell you which unit the sub-code is pointing to.
3/14/2011 2:19:14 AM •
Canon...
Answered
on Mar 14, 2011
Our small office (5 computers)
There are 2 drivers that I need to configure:
ir-PSv 1.81 MAC OS X.hqx
PPD. v 2.55.zip
To use the Canon PS v1.81 driver, you first of all need to run the
included PS installer, so that the files get copied to the Mac. At the
end of the installation you will be prompted to restart. You must do
this for the installation to complete correctly.
After
restarting, you are ready to add the printer. Now, the PS driver does
not support AppleTalk, so you will not be able to browse to the printer.
You will have to know the IP address of the iRC3220 to add the printer
queue. Once you have the IP address, you select to Add and then select
More Printers. From the top menu select Canon IP (PS). This will present
a dialog for entering the IP address of the iRC3220 and a queue name,
which is usually LP. Click Add and the software will then select the
appropriate PPD so that when the printer is displayed in the Printers
list, the Kind section will show Canon iRC3220.
Note that with
the PS driver installed, you do not require the PPD's as well. But if
you did want to use them, which would be the case if you wanted to use
AppleTalk, then you should find them located under Canon when you
browse. Note that like the PS driver, you do have to run the installer
included with the PPDs in order for the files to be copied to the Mac.
The
last thing to mention is that the iRC3220 also has an external print
controller option called an imagePASS-C1 or C2. This is a white metal
box that hangs on the back of the copier. If you do have an imagePASS
connected to the copier, then the two drivers you have downloaded are
not suitable for this print controller. You will need to download the
drivers for whichever model of imagePASS you have.
Hope this helps. (quoted from some forum)
11/2/2010 2:50:02 PM •
Canon...
Answered
on Nov 02, 2010
At work we have no
For Postscipt file you need to convert it into pdf format then you can print is other wise you need postsciprt supported software on computer.
You can conver postscript file .ps extension to pdf with acrobat distiler.
If your printer works fine with another software then only issue of postscript file .
You need to convert ps file to pdf .
But if your printer is not working with any software from computer then you need to unistall driver and then reinstall.
If you use windows then you can uninstall form control panel and device manager.But if you use mac then go to system preffereces ->library and delete printer driver folder from there then install driver.
Let me know if you need further assistance.
Thanks for uisng FixYa.
6/15/2010 3:41:03 PM •
Canon...
Answered
on Jun 15, 2010
