20 Most Recent
Canon S520 InkJet Printer Questions & Answers
I have replaced the black
Please check the seating of black ink cartridge. It may not have been placed correctly. Please replace it and then carry out the print head alignment.
How to install the Canom s520
Connect the printer, if your system is XP it should find it and install it from its own resources
If That does not happen, go to Start/Printers and Faxes./Add a printer
Click on this- Click on 'Select from list. Select Canon, scroll down to your model or if it is a new machine to a model in that series
click OK
Not printing
make sure your ink carts are in the right way...believe it or not ive made the same mistake and also make sure the color carts are in the right place!!!!
Ink jet printer will not print. Canon Pixma ip1880
If you could count the exact number of times the light flashes that would help. If it is 15 exactly, you need to replace your FINE cartridge. If that doesn't help, the carriage may need to be serviced.
Canon s520
Hello, try downloading a current working driver at the canon website (google canon, it will take you to the site list, go to drivers, type in your model and download to pc. Save new driver n disk in case of needing a reinstall later. Make sure you uninstall all drivers for the printer first then install new one. Good luck.
No destinations are set.
I had the same problem. It turned out my printer was set to print on the "Canon Fax" printer rather than the regular Canon printer. So I changed the printer on the print box screen and was able to print as usual.
Paper jam canon
Hi Jonatas Bila, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
