20 Most Recent Dewalt DCF885 20V Max* Lithium Ion 1/4" Cordless Impact Driver with Ion Battery Questions & Answers
Wondering if anyone knows whats wrong with my drill...when i press the trigger the drill works sometimes and not others
Open the tool and control the purple and brown colored wire where the slide contacts are fitted on the carbonbrush holder or the switch itself.Do allways the Battery slide connector contacts control Remove the two sliding contacts loose and squeeze the contacts slide a bit and then connect again.If unsuccessful buy a new switch as well as battery connectors are checked.
10/12/2016 11:00:08 AM • Dewalt DCF885... • Answered on Oct 12, 2016
Torque adjustment collar very difficult to turn
try spraying some lube like WD-40 in the chuck as it is faceing up and let it set overnight it may got some moisture in it . hope this helps.
9/13/2016 1:59:01 AM • Dewalt DCF885... • Answered on Sep 13, 2016
Hi i got new springs for the sleeve to hold the bit it do you what order they go in or do you have a photo of how it goes back together
Go to this site and it will show you what you need to know. https://www.youtube.com/watch?v=PQ8lSB_mP1c
9/13/2016 1:54:21 AM • Dewalt DCF885... • Answered on Sep 13, 2016
Dewalt DCF885 20V Lights up but nothing else will not work
It could be something as simple as the brushes
10/12/2015 12:31:44 AM • Dewalt DCF885... • Answered on Oct 12, 2015
Dewalt dcf885 will not lock the bits in
It could be the little spring at the back of the chuck sleve is broken ot one of the locking balls is missing.
4/4/2013 9:48:28 AM • Dewalt DCF885... • Answered on Apr 04, 2013
DeWalt planer leaving little gouge marks on the board. Recently had a new chain installed. Any help would be greatly appreciated.
It needs new blades - likely has a chip in one. See link for replacement tutorial
6/14/2022 4:37:07 PM • Dewalt Tools &... • Answered on Jun 14, 2022
Dewalt dc618 nail gun won't shoot
https://www.weeklytools.com/dewalt-angle-grinder-buying-guide/ When it comes to Angle Grinder, the name of the Dewalt tools maker comes first. We will look at the basic parts and functions of a grinder before purchasing a machine. Then let's see the details without delay.
3/13/2021 8:23:58 PM • Dewalt Tools &... • Answered on Mar 13, 2021
How do you change blades on DeWalt DW50 planer
https://www.weeklytools.com/different-uses-for-an-angle-grinder/ An angle grinder is a multifaced handheld power tools that was invented by a German company. We may don't know a lot about this tool because it is an unrecognized instrument like some other tools. Now we will discuss different Uses for angle grinder. An angle grinder is also known as a side grinder or disc grinder. It is a machine with a rotating abrasive cutting disc. Angle grinders can be powered by an electric motor, petrol engine, or compressed air. It comes in a wide variety of different sizes and powerful motor, each with the other purpose. Once anyone knows about these, he can easily find out the best angle grinder for his needs. Angle grinders are quality fulled equipment for any metal fabrication shop, and those are typically used in auto repair, workshops, and construction sites.
3/13/2021 8:22:33 PM • Dewalt Tools &... • Answered on Mar 13, 2021
Model DC618 nail gun. Why does it start, then shuts down as soon as I depress to fire nail?
https://www.weeklytools.com/how-to-use-a-nail-gun-with-an-air-compressor/ We may not need a drill machine almost the whole time. But there is a demand for a pilot hole during the home finishing process. This post is not for you if you are a professional. However, in most of the cases, we observe the necessity for a pilot hole. From wooden doors and windows ...
3/11/2021 9:28:06 PM • Dewalt Tools &... • Answered on Mar 11, 2021
Adjustment of sharpened cutter of porter cable 653 versa plane
There are two adjustments. First find the screw on the right side that allows loosening of rear baseplate. Once loose, another screw jacks the base up or down. They are both hex heads on mine.
Turn jack screw until a straight edge along the base just clears the cutter. Spin the cutter once to make sure both edges are the same depth and that both clear the straight edge.
For the front shoe, turn adjustment handle to zero. Remove the adjustment handle from the front shoe and find two vertical slots at the front. Two screws (hex heads) allow loosening of shoe. Once loose, the shoe can be adjusted by sliding up or down. With a straight edge held along the rear base and touching the front base, align the front shoe so straight edge barely clears blade and tighten screws. The front and back base should line up. Replace adjustment lever and recheck zero cut clearance as well as maximum depth. Readjust as necessary. If zero clearance is not an issue, the bases can be set to allow deeper cuts than factory specified. It's a powerful planer so if you're cutting softer woods, a deeper cut might be desired.
2/3/2021 5:13:02 PM • Dewalt Tools &... • Answered on Feb 03, 2021
My dewalt 1223 brad nailer will not fire
The nailer must be firmly pressed against the surface you are planning to nail. This will arm the nailer in preparation for firing the nail.
10/3/2019 9:15:00 PM • Dewalt Tools &... • Answered on Oct 03, 2019
Speed control wire around on DW423 sander
Try this link: https://www.ereplacementparts.com/dewalt-dw423-type-inch-evs-random-orbit-sander-parts-c-1009_2742_2758.html
4/2/2019 10:42:12 PM • Dewalt Tools &... • Answered on Apr 02, 2019
Changed blades on 733 dewalt planer now rollers not working could it be associated chews up broards
Either the blades are incorrectly installed causing the head to jam or the safety cover is not installed properly - there is a safety mechanism that locks the cutter head when the cover is removed.
2/2/2019 6:38:10 PM • Dewalt Tools &... • Answered on Feb 02, 2019
Hi my new dewalt first fix nailer(2018) will fire a few nails but then the battery light starts flashing? does this with all 4 of my batteries fully charged
Typical cause is low voltage - but can also be a bent driver or something jammed in the nail track. Is this a finish nailer or framing nailer?
2/2/2019 6:35:23 PM • Dewalt Tools &... • Answered on Feb 02, 2019
Dewalt DCF885 20V Max* Lithium Ion 1/4" Cordless Impact Driver with Ion Battery Logo
Popular Tags
5 questions posted
Top Dewalt Tools & Hardware - Others Experts
john h
Sean Wright
Sean Wright
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Dewalt Tools & Hardware - Others
Most Popular Question
wondering anyone knows whats wrong
  • Tools & Hardware - Others
