20 Most Recent Zanussi 5.76 cu. ft. / 163 liter Chest Freezer ZCF57 Questions & Answers
You did not specify which lights are on?
  • The green pilot light will illuminate to show that the appliance is switched on.
  • The red alarm light will also illuminate until the freezer
    reaches the correct temperature.
  • If you press the SUPER button than you start fast freeze function and yellow light will illuminate.
I assume that the freezer is on and the green light is illuminated. This means that the freezer is on and energized.
Also, if freezer does not cooling, means that did not achieve the set temperature should be illuminated the red light (alarm).
Set the thermostat for example in position 4th and after that compressor should be start.
If compressor running but not cooling, defective is the system which circulates gas.
If compressor does not start, then is faulty thermostat, compressor or the wiring.
Dado
Zanussi 5.76 cu.... | Answered on Oct 04, 2015
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Zanussi 5.76 cu.... | Answered on Jun 25, 2013
dear sir/madam
make sure first your freezer,s condenser fan motor is working if it,s working and its not getting good cool then it can be low gas problem so please contact to your maintenance personnel for find out the leakage and make it brazing and after refill refrigerant gas.
hope answer the question
thank you
please vote!
Zanussi 5.76 cu.... | Answered on Sep 16, 2010
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Zanussi 5.76 cu.... | Answered on Aug 23, 2010
CHECK YOUR CONNECTION TO THE ELECTRICAL PANEL
Zanussi 5.76 cu.... | Answered on Apr 08, 2010
try plugging the electric cord into a receptical
Zanussi 5.76 cu.... | Answered on Mar 27, 2009
I believe that a short circuit creates a defective light bulb inside the refrigerator or some other element in its circuit (door switch, lamp socket, wiring).
Dado
Zanussi Freezers | Answered on Dec 21, 2016
For such a procedure you should have knowledge and a lot of expensive work condition like:
- Vacuum pump
- Charging station
- Manifolds
- Recovery station
- Electronic charging scale
- Electronic leak detector or UV leak detector
and so on ......
The situation is further complicated by some of the new environmental gases which are explosive so you need to be qualified and trained person. It is best to leave that to the specialist or qualified service personnel.
Dado
Zanussi Freezers | Answered on Jan 16, 2015
Probably is switch for fast freezing mechanically defective.
Dado
Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Dado
Because it does not achieve the correct temperature (for example: -18 degrees centigrade).
For a more precise answer I need more information.
A lot of things may be incorrect:
- Doesn't work defrosting cycle
- The cooling fan is not working
- Too much ice on the evaporator battery
- Faulty thermostat or NTC sensor
- Faulty cooling system (gas leak)
- Compressor
- Electronic
Dado
It sounds like the door got shut when something in the jam and you may need to loosen the hinge, realign the door and tighten the door hinges again. Easier with 2 people but not impossible with 1.
Zanussi Freezers | Answered on Mar 03, 2014
Zanussi 5.76 cu. ft. / 163 liter Chest Freezer ZCF57 Logo
9 questions posted
Top Zanussi Freezers Experts
ray gallant
Dado
Kami
Are you a Zanussi Freezer Expert? Answer questions, earn points and help others
View Most Popular
Zanussi Freezers
  • Zanussi Freezers
Most Popular Question
light but freezer not cooling
  • Freezers
