20 Most Recent
Zanussi 14.62 cu. ft. / 414 liter Chest Freezer ZCF146 Questions & Answers
There are 3 lights on the front of the Zanussi
Starting the Appliance
Insert the plug into the wall socket. The green pilot light will illuminate to show that the appliance is switched on. The red alarm light will also illuminate until the freezer reaches the correct temperature.
Alarm Light
The red alarm light will illuminate when the temperature in the freezer is higher than the thermostat setting. This alarm light will illuminate if:
- The appliance has just been started.
- Fresh food has been put in the freezer.
- The lid has been left open, opened frequently or open for too long.
The red light will go out when the freezer has returned to the correct temperature
Dado
How to add refridgerant gas to an lg fridge freezer
For such a procedure you should have knowledge and a lot of expensive work condition like:
- Vacuum pump
- Charging station
- Manifolds
- Recovery station
- Electronic charging scale
- Electronic leak detector or UV leak detector
and so on ......
The situation is further complicated by some of the new environmental gases which are explosive so you need to be qualified and trained person. It is best to leave that to the specialist or qualified service personnel.
Dado
Why is the red light flashing on my zft810fw freezer when it is freezing ok inside
Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Dado
Why is Zanussi frost free freezer alarm always flashing
Because it does not achieve the correct temperature (for example: -18 degrees centigrade).
For a more precise answer I need more information.
A lot of things may be incorrect:
- Doesn't work defrosting cycle
- The cooling fan is not working
- Too much ice on the evaporator battery
- Faulty thermostat or NTC sensor
- Faulty cooling system (gas leak)
- Compressor
- Electronic
Dado
Door will not close
It sounds like the door got shut when something in the jam and you may need to loosen the hinge, realign the door and tighten the door hinges again. Easier with 2 people but not impossible with 1.
Zx99 fridge freezer not freezing and intermitent
Hello....Sounds to me like the fridge is getting low on refridgerant gas...If it is an older unit...it may have developed a leak over time and may just need a recharge.Get a quote from a repairman...most of the time..it is not very expensive to fix unless there is a problem with the compressor....I hope this was helpful....PEACE....
