20 Most Recent Buffalo Tools Pro-series 7000 Watt Silent Diesel Generator - 19N13GH Questions & Answers
The breaker itself is worn and weak. Replace it.
Buffalo Tools... | Answered on May 18, 2014
wet plugs,exceeding max load of circut,whatever it is running has a short in it.
Buffalo Tools... | Answered on Dec 21, 2012
have the voltage regulator system checked
in the regulator the voltage controls the amperage allowed and it that unit is not working properly then there will be no current out put
that regulator could be part of the control board for the main ac out put and may have developed a fault in the section for 12 volts on the board
there is a limit on the charge rate for the battery and if it is exceed it may have damaged that circuit or possible blown a fuse in the amperage circuit
Buffalo Tools... | Answered on May 08, 2016
if you cannot get the specs from on line or from a service agent , generally the following apply:-
water cooled engines
inlet hot .010"--exhaust hot .012"
for air cooled engines inlet hot .012"-- exhaust hot .014"
Buffalo Tools... | Answered on Sep 25, 2015
HOPE THIS LINK WORKS.
http://www.buffalotools.com/manuals/gen154manual.pdf
it is the Gen you got, I have same.. Condenser failed after 7 yrs. Just suddenly stopped putting out. Kept running nicely though!
Had the ' engine m/n invalid shut down on my 12resv Kohler generator. Off light was blinking red. Clicked the select button 3 times to clear fault and confirmed Y ...then went to the Gen set information which is a few more menu down with the arrow button. It did say 12Resv so had it blink and rest it but same thing. so rest fault again and went back to the gen set information tab and I changed it to 14resv and all cleared without out fault and tryed to hit run for a min . Ofcourse it's wrong model number so would not start but did not fault. So I went back to the Gen set information menu and put it back to the original 12Resv and it started right up without fault. I placed back in Auto and been working ever sense. Has friend had same problem and as with mine it happened on a night where power went on and off multiple times. Think its really just loosing informsiton to recognize the unit to controller and needs reset or flashed if you have the OnCue will work as well....one more thing good idea I'd not sure your battery is good over 12v to pull terminals and physically check with a multi meter should be liek 13 4 volts or so for optimal starting. Good luck this was a head ache and see others have had problem ..tony Michigan
Electrical... | Answered 3 days ago
High and Low Temperature Operation
Air temperature affects generator output. Output drops 1% for each
If the engine does not start:
1. Check the fuel tank for sufficient fuel. Refill with fresh gasoline if necessary.
2. Check the engine oil. Fill to the upper limit with fresh oil.
3. Ensure that the fuel petcock is open. The fuel petcock is open when the lever is perpendi-
cular to the ground (straight up and
If there is no power to the receptacles:
1. Turn the circuit breaker switches off and disconnect all electrical loads from the generator.
2. Turn the circuit breakers on and test the GFCI's by following the procedures in this manual
on page 1.
3. Place the voltage selector to the 120 Volt only positions (unless you are using a tool that
requires 240 Volts).
4. Turn the idle control switch off.
5. Turn the circuit breaker(s) off and reconnect the electrical loads. Be sure that the plugs are
securely connected to the receptacles.
6. Turn the circuit breaker(s) on.
7. If there is still no power at the receptacles, take the generator to an authorized D
service center. To locate a D
WALT service center nearest to you, call 1-800-4-D
E
Electrical... | Answered on Jan 22, 2020
we cant see it how would we know?? if it did youd see it
Electrical... | Answered on Jan 15, 2020
If you need to purchase diesel generator set, please refer to www.dieselgeneratortech.com
Generally, the kits save you a couple hundred dollars over buying each tool separately. Plus, a tool might be included in the kit that you don't usually use but that you find to be very handy and it might become your new favorite tool
Electrical... | Answered on Jan 13, 2020
If you have decided to opt for the CRUD dashboard Generator, you are certainly taking a wise move. This is an application that simplifies the hassles and hardships in managing and administrating the MYSQL databases. Using this application, users can design the best dashboard administration panel that aids the process of analyzing the databases. This application comes with more than 20 themes and templates. You can easily customize these templates to instantly design your own dashboard administration panel that will enable you to handle the database in the most proficient manner. As such, you can certainly opt for this application with a good faith and confidence. Reviews about this application comes exceptionally positive. This implies, the application has earned the appreciation from database professionals from all around the globe. One can Learn about crud php mysql atphpcrudgenerator.com. For more information about this application, please visit https://www.phpcrudgenerator.com/ now!!
Electrical... | Answered on Jan 12, 2020
CHECK WITH THE MANUFACTURER
Buffalo Tools Pro-series 7000 Watt Silent Diesel Generator - 19N13GH Logo
2 questions posted
Top Buffalo Tools Electrical Supplies Experts
Lawrence Oravetz
wadingriver
wadingriver
Bill Boyd
Are you a Buffalo Tools Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Buffalo Tools Electrical Supplies
Most Popular Question
generator breaker keeps tripping under
  • Electrical Supplies
