20 Most Recent
ASUS A2400H Notebook Questions & Answers
Cant connect asus computer to tv via hdmi
Try turning both pc and tv off and connect, then turn both on. Also, make sure your Display setting are correctly configured. Goto Control Panel, Display and click on Settings Tab. If your still having trouble. Try changing your resolution and make sure that you have your TV to the right input. My TV has 4 HDMI 3 RCA 2Component 1 Digital Optical many USBs...can get kinda confusing. The connection should be numbered. Switch inputs with your remote til you get the right port. Then work on getting your pc to display correctly. Set your aspect ration to 16:9 first. Most tv and laptops are set this way. GOOD LUCK let me know how it goes.
Asus ux50v, trying to connect
Welcome to Fixya.
Before you plug in your cable from your laptop to your HDTV, be sure to set
the resolution to one that is compatible with your HDTV. If your
computer monitor and your HDTV only share one common resolution, set it
to that until after you get a picture on the HDTV, then change it to
the desired resolution. When possible, always try to use the displays
native resolution. For example on some HDTVs the native resolution is
1280x768.
Hope this helps.
My asus a2400h notebook won't turn on
check adapter plug fuse
press on/off button for 5 sec's or so
press Fn-F1 for two sec's or so
press FN-F5 for 1 sec or so (Ring --0870--120--8340)--Asus helpline
Please advice what kind of memmory is installed in
SO-DIMM DDR - maximum capacity 2 GB . Pick one
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010170381%201052907864&name=200-Pin%20DDR%20SO-DIMM
It's under the keyboard, just push in a hole at the top right near the speaker to get the panel off first.
No power ..
have you check your hardware devices? specially the memmory and the video card of your laptop...disconnect it and connect again then power on the laptop
I just tried connecting my asus tower to my
Probably to do with the resolution. If your video card supports, get twin display on your computer while you fiddle about with the resolution for the TV, can't remember off the top of my head what is the best at the moment, but hope that points you in the right direction. ;)
Asus A2400H sound problem
yea go to website what provide your system soport and you should beable to a driver or hadeware for it
A2400H modern driver
You can find any drivers you want here>
http://www.asus.com/
You will have to download all the drivers needed by your motherboard and install them also.
Unless you have a setup cd com with the computer..
Asus A2400H Audio driver
I believe the following link and choosing the green auto direct to download page will take you to the right place. Other I am less sure the proper answers to the adjoining boxes are notebook, a2000 series and a2h from top to bottom.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Problem with asus
You may want to just try drying it out, put it someplace warm with airflow. I have forced air heat so in my case I would put it by a air duct. Let it dry for 12 to 24 hours, then try again. Let us know how it goes, and we'll see what else we can do.
Help my laptop screen is low resolution
You will need to find your graphics card make and go to the notebook manufacturer website and download the graphics drivers.
If you have a Recovery CDROM that you got with the notebook, explore it and the drivers will be in it along with sound and touchpad drivers.
