20 Most Recent
Reebok CS-4 Pedometer Questions & Answers
REEBOK GT30 TREADMILL. It has ERROR E2. What does this mean please?
E2 Error usually indicates that the treadmill is overloaded and applies to various models like TR150, TRX1000 and TR 200. To fix this problem, check if your treadmill motor is overheating. Signs of an overheated motor include; grinding noise, motor produces a burning smell and inconsistent operation speeds.
Reddit · r/fixit
3 comments · 4 years ago
Hi i have a reebok one gt30 treadmill bought in 2016. Recently at ... Start googling error codes and find out what E2 means. Upvote 2
Which part of my broken treadmill should I try replacing? - Reddit
Apr 18, 2020
Urevo 2-in-1 giving e10 error message- did you encounter this ...
Oct 10, 2022
Need help with Sole F63 treadmill error code - Reddit
Nov 21, 2022
More results from www.reddit.com
Reebok jet 300 treadmill e02 error - motor output dc is 11v on ...
All About Circuits
https://forum.allaboutcircuits.com > threads > reebok-j...
Jan 9, 2023 - It seems to me to be a problem in the circuit that gives feedback to the processor about the voltage in the motor, error02 and does not arm the ...
Missing: GT30 ' Show results with:
GT30
Treadmill Support - Reebok Fitness
reebokfitness.info
https://www.reebokfitness.info > treadmill-support
View user manuals, assembly guides, instruction books, and technical support videos for all Reebok treadmills, including how to reduce static shock.
Hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
Reebok treadmill e13 error message
f the E13 error code is still showing after restarting your treadmill, check to ensure that the wiring between the AC motor drive and motor cables is securely connected. If any of the cables/connectors appear loose, completely power off and unplug the treadmill before unplugging and reattaching the cables.
Reebok 8000ES stuck incline position will not decline.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwj79pDHxZSCAxV_AHkGHbhiDxkQFnoECBsQAQ&url=https%3A%2F%2Fwww.justanswer.com%2Ffitness-equipment%2Fgdah0-reebok-8000es-treadmill-incline-keeps-going.html&usg=AOvVaw0mEH-BLg44uwLpy6jJGb3K&opi=89978449
Reebok GTS40 treadmill not working
Hi Chris,Hope so you're doing well, fact that it runs briefly and then flips the fuse suggests a potential overload or short circuit problem. To troubleshoot the issue, start by checking the power source and ensuring that the circuit breaker or fuse can handle the treadmill's electrical load.Inspect the power cord for any signs of damage, fraying, or loose connections. Make sure it is securely plugged into the outlet. Additionally, examine the motor control board for any visible signs of damage, such as burnt components or loose wires.Testing the motor by disconnecting the power and manually rotating the treadmill belt can help identify any obstructions or issues with the motor or belt tension. If you are unable to identify or resolve the problem on your own then download now user guide, it is advisable to consult a qualified technician or contact the manufacturer's customer support for further assistance.Hope so this will help you!Regards,Bryce JuneCEO & Founder of https://trafficriderapp.com/
Reebok ONE GT40s incline working intermittently
It sounds like there may be an issue with the incline motor or the lifting mechanism. Here are a few troubleshooting steps you can take:
- Check for any visible damage or obstructions in the incline mechanism. Make sure that there is nothing blocking the movement of the incline motor or lifting mechanism.
- Check the wiring and connections for the incline motor. Make sure that all wires are connected securely and that there are no loose or damaged wires.
- Test the voltage going to the incline motor. Use a multimeter to check that the motor is receiving the correct voltage.
- Try to manually adjust the incline. This will help you determine if the issue is with the motor or the lifting mechanism. To do this, unplug the treadmill and remove the motor cover. Locate the incline motor and manually turn the screw with an Allen wrench to raise or lower the incline. If the incline moves smoothly and easily, the issue is likely with the motor. If the incline is difficult to move or doesn't move at all, the issue is likely with the lifting mechanism.
If you're not comfortable performing these steps, it may be best to contact a professional to diagnose and repair the issue.
My Reebok 9500 ES Treadmill is stuck at it's max incline.
- Check the belt: Make sure the belt is properly aligned and tensioned, as a misaligned or loose belt could cause the incline to get stuck.
- Check the incline motor: If the incline motor is not functioning properly, it could be preventing the incline from moving. You may need to have the motor inspected or replaced.
- Check the incline sensors: If the incline sensors are not functioning properly, they could be preventing the incline from moving. You may need to have the sensors inspected or replaced.
- Check the control board: If the control board is not functioning properly, it could be preventing the incline from moving. You may need to have the control board inspected or replaced.
If these steps do no
My Reebok Jet 200 is stuck at an incline
If your Reebok Jet 200 treadmill is stuck at an incline and you are unable to lower the incline to the 0 position, there are a few things you can try to fix the problem:
- Check the incline motor and make sure that it is properly installed and functioning. If the motor is damaged or not functioning properly, it may be causing the incline to remain stuck.
- Check the incline control board and make sure that it is properly connected to the incline motor and other treadmill components. If the control board is damaged or not functioning properly, it may be causing the incline to remain stuck.
- Check the incline cable and make sure that it is not frayed or damaged. If the cable is damaged, it may be causing the incline to remain stuck.
- Check the treadmill's belt and make sure that it is properly aligned and tightened. If the belt is misaligned or loose, it may be causing the incline to remain stuck.
- Check the treadmill's power supply and make sure that it is properly connected and functioning. If the power supply is not functioning properly, it may be causing the incline to remain stuck.
If you have tried all of these steps and are still having issues with the incline on your Reebok Jet 200 treadmill remaining stuck, you may want to consult a professional for further assistance. A treadmill repair technician will be able to diagnose the problem and recommend the best course of action to fix it.
