20 Most Recent Zanussi WJD1257W Front Load Washer Questions & Answers
Door doesn't unlock, won't start a program
it might just need an update,if not the main board could be going to fail hope not ,not cheep
11/3/2017 2:25:54 PM • Zanussi WJD1257W... • Answered on Nov 03, 2017
0answers
Stoped 5 minutes in to program , now won't start
Loved you in Pretty Woman, but The Mexican was just sh!te.
9/13/2013 3:39:59 PM • Zanussi WJD1257W... • Answered on Sep 13, 2013
0answers
The liquids in the softenner department is still there when it finishes why
it could be that one of your water valves have a open circuit your have 3 valves 1 lets in hot water 2 lets in cold water 3 lets in cold water to take the fabric softner away how ever it may be blocked up take out the draw and clean inside up the top where the holes are and then clean the draw if this does not work let me know i may be able to help futher
11/19/2011 5:24:41 PM • Zanussi WJD1257W... • Answered on Nov 19, 2011
Hi my machine seems to be stuck on 49mins and will
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
9/18/2011 11:26:48 AM • Zanussi WJD1257W... • Answered on Sep 18, 2011
Transport screw
Not sure what u need ......
12/24/2010 3:17:44 PM • Zanussi WJD1257W... • Answered on Dec 24, 2010
Zanussi WJD1257W Front Load Washer Logo
52 questions posted
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Zanussi Washing Machines
Most Popular Question
zwf160070w1 washing machine only 18
  • Washing Machines
