20 Most Recent Zanussi FJD1266W Front Load Washer Questions & Answers
Where is the water thermostat lokated
Normally this is near the heater element ,round with several wires on it
2/23/2011 9:08:52 AM • Zanussi FJD1266W... • Answered on Feb 23, 2011
Err 85 what soes it
E85 indicates that the circulation pump is faulty.
You'll need to check the circulation pump, it sits behind the drain pump. If it's obviously burned out you'll need to replace it.
The service manual states, circulation pump, wiring or main pcb as the cause.
In reality, the pump burns out/goes faulty and takes the main PCB with it.
Have a good look at the pump and also the main PCB.
12/4/2010 1:45:45 PM • Zanussi FJD1266W... • Answered on Dec 04, 2010
E30 use washer once the second time the machine
E30/31 - A motor drive problem has occurred. Try running the program again.
Many times simply checking the motor's wire harness plug - it has vibrated loose.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
9/17/2010 10:40:50 PM • Zanussi FJD1266W... • Answered on Sep 17, 2010
Rubber drive band snapped and took out a earth and
any electrician should be able to repair this if you have the machine's cover off;
In fact you could do it yourself with a soldering iroin to replace the spade bit on the wire and some shrink rubber tubing which will allow you to join in any extra wire.
Cost to fix about $10 DIY and $50 by Mr Fixit type
Please rate my help++++Thanks for using FIXYA
5/31/2010 11:42:07 AM • Zanussi FJD1266W... • Answered on May 31, 2010
Not spinning and emptying
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
5/17/2010 4:23:43 AM • Zanussi FJD1266W... • Answered on May 17, 2010
Brown marks on clothes
Does the drum sound noisy when it spins if it does then I would suspect the bearings are badly worn and the grease from the bearing is getting inside the drum.
Hope this helps.
5/16/2010 10:05:37 AM • Zanussi FJD1266W... • Answered on May 16, 2010
How do you change a door seal
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
1/19/2010 7:01:58 PM • Zanussi FJD1266W... • Answered on Jan 19, 2010
WASHING CYCLE STOPS AFTER A MINUTE
Can you skip through the programme to drain? Press pause button. then press start to move the lights down to the empty cycle. leave to finish.
If you have already tried this, I can explain how to put machine into engineer test mode, which will then give out a fault code to identify problem.
4/6/2009 9:19:27 AM • Zanussi FJD1266W... • Answered on Apr 06, 2009
E90 error
electrician checked wires in pcb board and display panel
problem corrected
1/11/2009 5:51:48 PM • Zanussi FJD1266W... • Answered on Jan 11, 2009
Noisy during some parts of the cycle
it could be the concrete ring situated at the front of the machine. i had the same problem with mine 2 years ago.
7/29/2008 8:35:38 PM • Zanussi FJD1266W... • Answered on Jul 29, 2008
Need dimension of Zanussi Aqua cycle 400
1/4/2024 9:07:00 PM • Zanussi Washing... • Answered on Jan 04, 2024
Zanussi Washer dryer ignoring all programs and just does a pulsing humming sound (Only works well on reset mode)
It seems like you've done a thorough job troubleshooting so far. The E69 error could be related to a heating issue. Since you've already replaced the heating element, it's worth checking the thermal fuse. The thermal fuse is a safety device that can sometimes cause E69 errors if it's faulty. Given that you have access to a spare machine, you might consider swapping the thermal fuse from the spare machine to see if it resolves the E69 error on your primary machine. If the spare machine's thermal fuse is in good condition, it could be a step toward identifying and solving the issue without having to switch the drums. Remember to disconnect the power source before attempting any replacements, and I hope this helps you get your tumble dryer back in working order.
12/5/2023 9:07:17 PM • Zanussi Washing... • Answered on Dec 05, 2023
Zanussi ZWF1640 - at start of wash, all the lights go off and it jumps to end of cycle
May try resetting the breaker turning off turn on
9/1/2023 7:50:24 PM • Zanussi Washing... • Answered on Sep 01, 2023
Zanussi ZWF1021W Washing Machine bearing replacement?
Take a look at the videos. You will need a bearing and seal kit, plus some grease. You can knock the old bearing out using a large socket on an extension bar. That is also useful for gently seating the seal without damaging it. https://www.google.com/search?q=Zanussi+ZWF1021W+Washing+Machine+bearing+replacement Later machines have the bearings bonded to the drum. Truly a bad idea! https://www.ukwhitegoods.co.uk/forums/forum/public-support-forums/help-and-support/washing-machine-help-forum/31703-zanussi-zwf1431w-bearing-replacement ..
7/28/2023 4:03:25 PM • Zanussi Washing... • Answered on Jul 28, 2023
Zanussi washing machine door seal metal wire ring has come off, how do I put it back?
To put back the metal wire ring on the door seal of your Zanussi washing machine, you can follow these steps: Ensure safety: Before starting any repair work, make sure the washing machine is unplugged from the power source to avoid any accidents. Locate the groove: Examine the door seal and locate the groove where the metal wire ring needs to be inserted. The wire ring typically fits into a groove on the inner edge of the seal. Position the wire ring: Take the wire ring and position it in your hands so that it forms a complete circle. Make sure the ends of the wire are close together. Start at the top: Begin by inserting one end of the wire ring into the groove at the top of the door seal. Apply gentle pressure and work your way around, pushing the wire into the groove. Use your fingers or pliers: Depending on the size and tightness of the wire ring, you may be able to push it into the groove using your fingers. If it's difficult to do so, you can carefully use a pair of pliers to assist you. Be cautious not to damage the wire or the door seal during this process. Continue around the seal: Slowly and steadily work your way around the door seal, pushing the wire ring into the groove. Take your time to ensure that the wire is securely in place and properly seated within the groove. Double-check the installation: Once you've inserted the entire wire ring into the groove, double-check that it is evenly positioned and properly seated. Ensure that it's securely holding the door seal in place. I'm Sophia and CEO of Homyclean, and I love sharing my amazing cleaning, laundry, bathroom, best washing machine cleaners and maintenance experiences with you. I'll share hassle-free methods and top-notch products for washing and cleaning, fueling your passion for cleanliness. By following these steps, you should be able to successfully put the metal wire ring back on the door seal of your Zanussi washing machine. If you encounter any difficulties or the wire ring doesn't fit properly, it's advisable to consult the manufacturer's manual or seek assistance from a professional technician.
7/2/2023 5:45:55 AM • Zanussi Washing... • Answered on Jul 02, 2023
Zanussi Lindo 300..keeps adding water to finishing spin cycle
If your Zanussi Lindo 300 washing machine keeps adding water to the finishing spin cycle, there may be a few possible causes. Here are some steps you can try to diagnose and fix the problem:
  1. Check the Drain Hose: Make sure that the drain hose is not clogged or kinked, which can prevent the water from draining properly. Try removing any blockages or straightening any kinks in the hose.
  2. Check the Water Inlet Valve: The water inlet valve may be faulty, which can cause the washer to continue adding water. You can try cleaning the valve or replacing it if it is faulty.
  3. Check the Pressure Switch: The pressure switch controls the water level in the washer. If it is faulty, it can cause the washer to continue adding water. Try cleaning the switch or replacing it if it is faulty.
  4. Check the Control Board: The control board is the brain of the washer and controls all the functions. If it is faulty, it can cause the washer to not operate correctly. Try resetting the control board or replacing it if it is faulty.
  5. Check the Door Lock: The door lock may be faulty, which can cause the washer to not enter the spin cycle and continue adding water. Try cleaning the lock or replacing it if it is faulty.
  6. Check the Motor: The motor may be faulty, which can cause the washer to not enter the spin cycle and continue adding water. Try resetting the motor or replacing it if it is faulty.
If none of the above steps work, it may be best to contact a professional technician for further diagnosis and repair. They can inspect the washer thoroughly and ensure that it is working correctly and safely.
3/9/2023 2:27:42 PM • Zanussi Washing... • Answered on Mar 09, 2023
Zanussi FJD1266W Front Load Washer Logo
23 questions posted
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Zanussi Washing Machines
Most Popular Question
brown marks clothes
  • Washing Machines
