20 Most Recent Apple iMac G5 Desktop Questions & Answers
Startup screen has apple with spinning wheel then screen goes black
probably bad, might be disk, ram or logic board. Try resetting pram and then try rebooting in safe mode by holding down letter s on start up. Try disk or drive select by holding down option key on start up. Make some effort, look up key commands on google and apple support.
7/28/2014 9:18:06 PM • Apple iMac G5... • Answered on Jul 28, 2014
How do I open and remove the hard drive?
Maybe this can help you
8/9/2012 9:07:12 AM • Apple iMac G5... • Answered on Aug 09, 2012
Thin black non-continuous line across screen that appears in different places at different times. MacPro
that is early indicator that screen is fragmenting only answer is to get a new monitor
5/30/2012 7:31:38 AM • Apple iMac G5... • Answered on May 30, 2012
PowerMac G5 doesn't eject
Your DVD wont show on the desktop unless a DVD is inserted. Which means that the DVD is either upside down, or simply isn't recognized by the reader. There should be an eject button on your keyboard. Hold that for 3 to 5 seconds and see if it ejects. If not, look for a tiny hole in the front of your case and insert a paper clip and push in until the DVD ejects. Some Macs have no hole and require a shop to extract the DVD for you. Another trick is to start up the PC while holding down the C key during bootup, which will make the PC try to boot off of the DVD. At which point the DVD should eject as the system asks for a proper boot cd.
5/17/2012 3:47:27 PM • Apple iMac G5... • Answered on May 17, 2012
In apple pc mac os and windows 7 are there problem is
You cannot install Windows on a Macintosh with a PowerPC processor.
10/22/2010 10:39:30 AM • Apple iMac G5... • Answered on Oct 22, 2010
I have an iMac g5 and an eMachine. I have
just connect both computers to the same router/hub. if mac is working then windows should work as well. on a wired network in windows xp and beyond, there is no set-up required. if it is not working, then perhaps you using a crossover cable (meant to connect 2 computers directly) instead of a regular ethernet cable.
9/30/2010 4:15:11 PM • Apple iMac G5... • Answered on Sep 30, 2010
Airport Extreme 802.11g
At this point you are much better off installing a USB wireless antennae than spending money on an Airport card, cracking open the iMac, and installing it.
USB wireless adapters are cheap, plentiful, and have more capabilities than the generation of Airport cards that were made for G5 iMacs.
8/20/2010 2:11:34 AM • Apple iMac G5... • Answered on Aug 20, 2010
I want to eject cd from cd rom apple system imac...
To eject a CD/DVD that is not recognized by your computer, boot up while holding down the eject button on your keyboard, and continue to hold down eject until the disk ejects.
If this does not work, hold down your mouse button while booting up in the same way.
If neither of these work, open Terminal and type in the following:
drutil tray eject
If your disc does still not eject, your optical drive likely needs repair.
8/20/2010 1:43:42 AM • Apple iMac G5... • Answered on Aug 20, 2010
2answers
Eject is stuck on my power mac g5
try a reboot and hold the left mouse button down during the startup. You can also hold the spacebar during startup. This should force eject the drive
2/26/2010 5:04:01 PM • Apple iMac G5... • Answered on Feb 26, 2010
How much does the imacg5 cost?
Why not "browse" the Apple Store:
http://store.apple.com/us/browse/home/shop_mac/family/mac_mini
to find the suggested retail prices?
1/9/2010 5:10:36 PM • Apple iMac G5... • Answered on Jan 09, 2010
Vertical stripes on the monitor, Imac G5
YOU ARE REQUESTED TO TIGHTEN THE PORT. THANKS REGARDS SIDDHARTHA
1/6/2010 5:19:37 AM • Apple iMac G5... • Answered on Jan 06, 2010
I have an Apple iMac G5 Intel dual-processor
Use Dr. Web live CD! It has a great built in file recovery tool
12/14/2009 11:47:10 PM • Apple iMac G5... • Answered on Dec 14, 2009
Trying to install an upgrade for mom's mac. The
You can try copying the disc to the computer and then running from there.
Before that though you should make sure you've got all the latest updates from apple via the Apple Software Update.
Know what I'm talking about?
11/20/2009 5:18:45 PM • Apple iMac G5... • Answered on Nov 20, 2009
Apple imac g5 desktop 17 boot disk boot hd
It sounds like your hard rive has failed. You could if you can ask someone for a loan of a disk utility such as disk warrior to check the hard drive. If it has failed have a look at the following websites on how to replace it
http://www.dtgeeks.com/index.php/features/tutorialview/imac_g5_hard_drive_replacement/
or
manuals.info.apple.com/en/imacg5_17inch_HardDrive.pdf
10/29/2009 6:17:17 PM • Apple iMac G5... • Answered on Oct 29, 2009
Imac g5 speaker has very loud buzz
Check the cable of your speakers or
Download another Music Player
10/24/2009 10:55:12 PM • Apple iMac G5... • Answered on Oct 24, 2009
My G5 2.0 dual core has recently stopped
Repair the permissions. <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/SgcYuH-Fpas&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/SgcYuH-Fpas&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
10/23/2009 6:13:47 PM • Apple iMac G5... • Answered on Oct 23, 2009
2answers
Imac wont boot message comes up
try another keyboard.
9/28/2009 4:50:38 PM • Apple iMac G5... • Answered on Sep 28, 2009
Start up
I can help you to fix this.Please let me know what error do you get. Post here and I'll let you know some steps to fix that.
Awaiting response
Thanks
9/9/2009 1:41:08 AM • Apple iMac G5... • Answered on Sep 09, 2009
20" iMac Boot
Ar this is a regular problem i get when people try to install Windows XP or Linux on Boot camp e.t.c.
What's happened is Linux has Tampered with the boot up files and now it won't be able to boot into Linux or Leopard.
What you need to do is insert you Leopard Install disk that came with you iMac Into the Disk Drive, the disk/disks are grey and may be two CDs or 1 DVD.
Restart the iMac and the moment you hear the chimes go off when it boots up, Hold down C on the keyboard. The boot disk for leopard will then boot up,
From here follow the instructions and if your lucky you may be able to upgrade, if not, go through the system utility and repair disk permissions e.t.c.
If nothing works, You will have to do a clean install,
But you may be able to recover a thew images and mp3 files with a great bit of software i like to use, http://www.prosofteng.com/products/data_rescue.php
You do have to pay for it, and you will need to install it on macbook e.t.c. if you have one in order for it to work If your confused there is a number of guides out there on that website or on google
Hope i have been of any help
Regards
7/28/2009 2:10:17 PM • Apple iMac G5... • Answered on Jul 28, 2009
IbookG4 optical drive wont disengage
Try to go into your system setup in control panel and roll back the driver you just updated back to the one it had, and disable automatic updates to that device.
7/7/2009 7:10:30 PM • Apple iMac G5... • Answered on Jul 07, 2009
Apple iMac G5 Desktop Logo
38 questions posted
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Apple Computers & Internet
Most Popular Question
imac g5 desktop with 20 m9250lla 1 80 gh
  • Computers & Internet
