20 Most Recent Honeywell 50250-S True HEPA Air Purifier Questions & Answers
Unit stopped working
I have the same problem. Cleaned filters, lights were never on to indicate they needed to be cleaned but i cleaned them anyway. Tried resetting lights by holding 10 seconds and nothing.....
4/29/2017 7:39:01 PM • Honeywell... • Answered on Apr 29, 2017
I bought a honeywell air
9/13/2023 3:52:34 PM • Honeywell Air... • Answered on Sep 13, 2023
I just cleaned the filters in my honeywell hepa air purifier and now it wont run on anything but low speed
You didn't indicate the model. Perhaps this support page from Honeywell can help. https://www.honeywellpluggedin.com/air-purifiers/support
4/13/2020 3:54:14 PM • Honeywell Air... • Answered on Apr 13, 2020
Why is Honeywell 52500 not working?
Honeywell does not have any serviceable parts. Get a new one.
10/24/2018 12:04:44 PM • Honeywell Air... • Answered on Oct 24, 2018
My Honeywell Enviracare 13520. the problem is that I can't get the handle to loosen.
Are you really unscrewing it? (to the left)? If not, then perhaps put a hammer handle on the handle at the outside rim and thump the hammer with the palm of your hand..
10/24/2018 12:00:55 PM • Honeywell Air... • Answered on Oct 24, 2018
Can you replace the control unit on a Honeywell air purifier model no.17007-HD
Normally Honeywell has NO replacement parts. Run it as is, then throw it away.
10/24/2018 11:56:55 AM • Honeywell Air... • Answered on Oct 24, 2018
I have a Honeywell HPA050 air purifier. Both filter lights started blinking, so I changed both filters; however, I cannot get the red filter lights to stop blinking. I've held them pushed in, I've unplugged the unit...the lights are still blinking. Help!
Ignore the lights. Wash the outer foam filter every two months. As long as air is going through the inner filter does not need to be changed. Blow the inner filter out FROM THE INSIDE with your vacuum cleaner. (blow air the opposite direction of air flow to get the nasty stuff off.)
10/24/2018 11:55:32 AM • Honeywell Air... • Answered on Oct 24, 2018
What is this burning smell from my Honeywell air purifier
am sorry to disappoint you, once this condition is reached, it means the motor windings have overheated and your motor needs to be replaced, This is the only best thing to do to rectify this situation. This indicates that the insulation covering the wire used to make the winding of the motor has been cooked by the overheating and it is shorting out ,THIS WILL CAUSE THE MOTOR CATCH FIRE. Please unplug the unit and have the motor replaced or buy a new unit for your safety.
10/20/2017 12:54:31 AM • Honeywell Air... • Answered on Oct 20, 2017
Putting filter back in a Honeywell air purifier model hfd-135
Hello, this is Ava with Think Crucial. You may refer to this online manual for your model number to help you put back the filters in your unit. Honeywell QuietClean HFD 110 Series User Manual You can purchase a wide variety of high quality Honeywell replacement parts for your Honeywell Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/search?type=product&q=honeywell I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
2/17/2017 12:41:48 AM • Honeywell Air... • Answered on Feb 17, 2017
Why does my new Honeywell air purifier give out a smell.
maybe its what ever its pulling out the air in the room its in.or it needs a clean
11/6/2016 8:03:50 PM • Honeywell Air... • Answered on Nov 06, 2016
How to reset indicator light on air filter
Hello, this is Ava with Think Crucial. When resetting your Intelli-Check Filter Indicator. the air purifier should be powered on. Press and hold the appropriate filter indicator button for approximately 10 seconds until the light turns off. You can purchase a wide variety of high quality Honeywell replacement parts for your Honeywell Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 http://www.thinkcrucial.com/search?type=product&q=honeywell I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
10/25/2016 10:49:42 PM • Honeywell Air... • Answered on Oct 25, 2016
Changed filter and pre filter both lights continue to blink, not resetting
Hello, this is Ava with Think Crucial. Make sure that the new filters you installed are undamaged and correctly seated in it's assembly. When resetting the unit, unit must be powered on then press and hold the appropriate filter indicator button for approximately 10 seconds until the light turns off. If nothings happens, unplugged the unit from the power for about a minute and then try to reset the unit. If all else fails, I would suggest to contact Honeywell for more assistance. You can purchase a wide variety of high quality Honeywell replacement parts for your Honeywell Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 http://www.thinkcrucial.com/search?type=product&q=honeywell I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
10/25/2016 10:43:40 PM • Honeywell Air... • Answered on Oct 25, 2016
2answers
Can somebody help fix the problem I'm having with my Honeywell air purifier....when I press power button it won't work all I see is red light any button I press red it wont do anything....pls!!!!.....
I have the same unit. Have you cleaned out the removable filters? also the red light at the bottom indicates the time to clean the filters. to reset it, use a paper clip. The red light on the bottom right is the filter indicator light, what looks like it should be a light beside that filter light, is actually a reset button, just poke it with a paper clip for a few seconds to reset. The bottom red light goes out
10/25/2016 10:19:23 PM • Honeywell Air... • Answered on Oct 25, 2016
Honeywell 50250-S True HEPA Air Purifier Logo
1 questions posted
Top Honeywell Air Purifiers Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
View Most Popular
  • Honeywell Air Purifiers
Most Popular Question
unit stopped working
  • Air Purifiers
