20 Most Recent Zanussi FLE1416W Front Load Washer Questions & Answers
When you put it to drain/spin does the pump make any attempt to drain,if not it could be that there is something stuck in the pump,needs draining manually.Another thing to try is to find the fault code.If you hold down the 2 buttons on the far right of panel then press on/off button till lights start chasing,then release the 2 buttons on right hand side.Now the first function button by the on/off button you will need to press until the light above the button reaches the 9th or 10th position this will give you a read out in the display.
E10 = low water press.
E20 = pump or filter.
E30 = press. switch or heater faults.
E40 = Door swich.
E50 = motor.
Some of these numbers can vary there are more but those are the most common.After checking codes switch off machine then back on twice to reset.
Hope this helps.
Zanussi FLE1416W... | Answered on Dec 29, 2015
clothes caught between inner and outer Drum, you have to get it out !good luck eire.
Zanussi FLE1416W... | Answered on Nov 15, 2015
Unplug machine and wait a few minutes and replug it in again! This usually resets the computer on the washer but be prepared if it happens on a regular basis you may need to call a qualified repairman that can troubleshoot the problem!
Zanussi FLE1416W... | Answered on Jan 02, 2014
A lot of times the hose gets just clogged. What you do is get a tea pot, and boil some water. Then carefully pore some hot water slowly down the drawer, little by little until it breaks up the soap to unclog it. Another affective way is buy a can of air in a can. Compressed air in a can is used for many uses, such as cleaning a key board or lightly blowing out electronics, can get it at almost anywhere they sell computers. Then you do small burst of air in the detergent drawer. However I would try the hot water first, and save some hot water for a cup of tea as your patience of having it work. Thanks Mike
Zanussi FLE1416W... | Answered on Apr 08, 2012
check brushes.
Zanussi FLE1416W... | Answered on Sep 11, 2011
Zanussi FLE1416W Front Load Washer Logo
79 questions posted
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
peter gittos
peter gittos
jimorris77
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Zanussi Washing Machines
Most Popular Question
zanussi fle 1416w wont fully drain water
  • Washing Machines
