20 Most Recent
Zanussi ZWF1420W Front Load Washer Questions & Answers
Drum paddles falling off
until you post the statement again and include such vital details like make model year type of equipment etc and photo then nobody has any idea of what you are on about
Any advice on how to
the door seal or do you mean the rubber boot that goes from outter tub to the outer frame simply seat the seal all the way around into the groved slot on the rubber boot and then attach the top of the retaining ring first and slide the left side on while holding the corner of the right side move your screwdriver from the top left furthest point in a couter clockwise direction until the metal retaining ring is half seated you can see down the bottom there is a small spring that allows the tension on the other side you would hold with a finger the last point that you seated the retaining ring and start on the top right side with your flat screwdriver and work your way clock wise until you came to the are with the spring then just put your screwdriver in the area where the spring is located and pry towards you walla this piece is also called door bellows to others as well it is termed as a rubber boot where I am currently if you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
p.s tomatoes dont grow particulary well with washer machine on top on the other hand a type of berry would have no problem at all :)
