20 Most Recent
Zanussi 18 in. DA4342 Free-standing Dishwasher Questions & Answers
My zanussi DA4342 lets the
I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher
SprayArms not Spinning
How to Buy
ApplianceParts OnlineA bad heating element causes many problems in dishwashers...
Dishwasher Problems The
HeatingElement not WorkingDishwasherMaintenance
DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
My dishwasher isn't rinsing properly,
Dishwasher
How to Buy
heatman101
Not cleaning properly
I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried in vainto clean the things...
Bought new spray arms online and installed them inminutes...now the thing works like new...
However I have also found that if the heating element goesbad then that also can mess things up bad...
So I would buy new spray arms, and also check out theheating element to make sure it is working...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts OnlineA bad heating element causes many problems indishwashers...
Heating Element not WorkingDishwasher Maintenanceheatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Hi there
Do you have it hooked up to hot or cold water supply? Most residential dishwashers don't come equipped with a booster heater. If it's connected to the cold side, you'll have to replace the angle stop with a single outlet stop and replace the hot angle stop with a double outlet stop. This should help out, if not, make sure you have hot water in the faucet before starting the dishwasher. Most dishwashers need at least 120 degree hot water supply.
No water getting to washer
Yes, but I would check to make sure power is getting to the valve before replacing. Usually if you hear a buzzing, then power is going to the valve. The best way is with a meter on A/C setting then put it on OHM setting to check the solenoids on the valve. I would buy a meter at an appliance parts store so they can show you how to use it. It's not that difficult and everyone should have one.
Tablets not dissolving
Sounds like whatever soap you are using is just too much soap your dishwsher can handle. The soap "packs" are usulally an overload of soap for most dishwashers. Just a few teaspoons of regular name brand soap sometimes will cure lots of dishwsher ills!!!
Zanussi da4342 dishwasher
The dishwasher should heat the water to about 55 C as the heating cycle starts.
In these cycle, the dishwasher pauses after has filled with water and wait for the water to reach the temperature.
If the water isn't being heated (because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues.
Another possible reason is that the timer unit is defective.
If you have observed anything different post a comment.
Upper spray arm came off
I have the DA4142 and if its anything like mine, the upper spray arm simply clips into place under the upper tray rack.
Zanussi DE4744 not heating at all
exercise to lose belly fat; fat loss extreme; workouts to lose belly fat; best foods to eat to lose weight; diet for weight loss for female; dr now diet plan; simple 1200 calorie meal plan; meal plan for weight loss and muscle gain female; 1200 calorie a day meal plan; lifting weights to lose weight; foods to eat to lose weight; lunch for weight loss; healthy lunch for weight loss; healthy foods high in fat;
https://behealthyideas.com/
<ahref="https://behealthyideas.com/">https://behealthyideas.com/</a>
1/18/2023 11:10:53 AM •
Zanussi...
Answered
on Jan 18, 2023
Zanussi ZDF26001XA code .30 anti flood device. how do i fix it without calling a mechanic?
Under the base of the machine, above the floor there is a tray with a sensor in it and that is what triggers the Flood Error Code. So the machine needs to come out, the back or side panel removed and the tray thoroughly dried. You also need to find where that water came from. If the salt container is in the base, it may be leaking if you were breaking up the salt.
11/30/2021 4:42:10 PM •
Zanussi...
Answered
on Nov 30, 2021
