20 Most Recent
Frigidaire Dehumidifier LAD704TDL Questions & Answers
After 3 min. of operation unit blows warm air.when turned of for 1 second and back on is o.k.for 3 min.
If it is an older unit, it may be low on Freon (they _do_ use freon). There is no way to refill a closed system. The only other possibility is a bad pressure switch, and again, it involves the type of appliance that nobody supplies parts for (and are usually not user serviceable anyway). Sorry. // Note: I considered not even replying with such a non-helpful answer, but I am certain of what I am saying and I don't want to see someone going crazy looking for a solution that has a high probability of not existing. // Sincerely, -Gregg
Dehumidifier freezes up
Good Morning Friend,
I understand your Frigidaire dehumidifier, model# LAD704TDL, is freezing up. If you have turned on your dehumidifier recently, this is normal due to refrigerant rushing through the coil. Frost will usually disappear within 60 minutes. Try starting your dehumidifier on a slower fan setting. Another possibility is that the room temperature is too low or too high. Your appliance is designed to operate between 41 degrees F (5 degrees C), and 96 degrees F (35 degrees C). I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Dehumidifier does not reduce humidity.
Good Afternoon Miguel,
I understand that your Frigidaire dehumidifier, model# LAD704TDL, is not reducing the humidity, due to the coils constantly freezing up. I also see that it is located in good temperatures and in a good position. I suggest contacting the manufacturer directly. They should be able to point you in the right direction to having your appliance fixed. Hope this is helpful.
-Best Regards-
WP
My frigidaire dehumidifier isn't not dehumidifying .is the warranty still good
I understand your Frigidaire dehumidifier, model# LAD704TDL, is not dehumidifying. I also see that it is blowing hot air, no water is coming out of the hose, and the humidity stays at 80%. I suggest contacting the manufacturer directly, to see if your appliance is in warranty, and they should be able to point you in the right direction. Hope this is helpful.
-Best Regards-
WP
Is there a call back on unit lad704tdl dehumidifier
I understand you are wondering if there is a recall on your Frigidaire dehumidifier, model# LAD704TDL. I see that the bucket is not filling with water when your appliance is running. I don't believe there are any recalls. I suggest contacting the manufacturer for further assistance. They should be able to point you in the right direction. Hope this is helpful.
-Best regards-
WP
Fridigaire dehumidifier compressor gets very hot and no water in bucket
I understand that the compressor is getting very hot and there is no water in the bucket of your Frigidaire dehumidifier, model# LAD704TDL. I would check to make sure that your dehumidifier has enough ventilation. There should be a minimum of 12 inches clearance around your dehumidifier. Also, make sure that it is neither too hot, nor too cold where you have placed your dehumidifier. Your appliance is designed to operate between 41 degrees Fahrenheit and 96 degrees Fahrenheit. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dehumidifier status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Condensation on frigidaire dehumidifier turn to ice
I understand that the condensation is turning to ice on your Frigidaire dehumidifier, model# LAD704TDL. This can be a possible cause of your dehumidifier being turned on recently. This is normal, due to refrigerant rushing through the coil. Frost will usually disappear within 60 minutes. Another possibility is the room temperature is too low. All dehumidifiers will operate satisfactorily at temperatures greater than 41 degrees Fahrenheit. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dehumidifier status has changed successfully. Hope this is helpful.
-Best Regards-
WP
