20 Most Recent
Frigidaire Fad704dud 50 Pt Pint Electronic Control Dehumidifier Low Energy Star Questions & Answers
Meaning of "F1" in a Frigidaire Dehumidifier model FFAD5033R1?
For the slightly larger model, FFAD7033R1, F1 turned out to be the humidity sensor. This can be accessed by removing just the back panel.If you have a soldering iron for less than a nickel you can just replace the NTC Thermistor (small orange resistor 10k) on the small PCB. See attached image below.In the image below just to the right of the white sensor you can see I removed the bad thermistor..
How to locate and replace internal filter?? For frigidaire
Good Afternoon Friend,
I understand that you are trying to locate and replace the internal filter for your Frigidaire dehumidifier, model# LAD304NUL. I also see that you cannot find your manual. To locate and replace the filter, follow these easy steps.
a. Remove the filter every two weeks based on normal operating conditions.
b. To remove the filter, remove Bucket then pull filter downwards.
c. Wash the filter with clean water then dry.
d. Re-install the filter, and then replace Bucket.
I have also included the link for your manual, where I found these instructions. Hope this is helpful.
-Best Regards-
WP
Frigidaire Manual Search Results
