20 Most Recent
Sunbeam 1964,1965,1966,1967 Tiger Badge/pin 64,65,66,67 Questions & Answers
How to rewire a renault 9 gtl '84 dash board
Start by getting a current schematic. If you are doing the whole dash, I would investigate several manufactures that have a pre-built wiring harness. Otherwise, buy some automotive wire and have at it.
5/6/2014 8:37:38 PM •
Sunbeam...
Answered
on May 06, 2014
O2 wiring for 2004 chevy Blazer
maybe a vacuum leak, a wiring issue, or a fuel delivery problem. What code is exactly coming up? Example: P0171 - o2 sensor too lean
3/31/2014 1:45:46 AM •
Sunbeam...
Answered
on Mar 31, 2014
Free wiring diagrams
I have a 2001 buick century and the instrument cluster and tail lights are not working - my friend changed the instrument cluster and head light switch and nothing still works. What do I do next?
3/16/2014 5:57:55 PM •
Sunbeam...
Answered
on Mar 16, 2014
Sunbeam BL0750 electric blanket green light blinking
Sure, here are a few suggestions on where to find a replacement controller for your Sunbeam BL0750 electric blanket:
* **Sunbeam customer service:** You can contact Sunbeam customer service directly and they may be able to help you find a replacement controller. Their contact information is available on their website.
[Image of Sunbeam customer service website]
* **Online retailers:** There are a number of online retailers that sell replacement controllers for Sunbeam electric blankets. A quick search should turn up a few options.
* **Local hardware stores:** Some local hardware stores may also carry replacement controllers for Sunbeam electric blankets. It's worth checking with your local store to see if they have any in stock.
Once you've found a replacement controller, you can either install it yourself or have a professional do it for you. If you're not comfortable installing the controller yourself, you can take your blanket to a qualified electrician or repair shop.
Here are some additional tips for troubleshooting your Sunbeam BL0750 electric blanket:
* Check the power cord to make sure it's plugged in securely.
* Try using a different outlet.
* Check the fuse or circuit breaker to make sure it's not tripped.
* If you've tried all of these things and the blanket still doesn't work, you may need to replace the controller.
I hope this helps!
