20 Most Recent Tricity Bendix TM310W Electric Dryer Questions & Answers
Light says tank full even though i have emptied it
[unplug the appliance before proceeding] At the back of the dryer close to the floor there is a white cap secured with a spring coil lock. Use a pliers to loosen the spring and remove that cap [make sure you have a towel in place as there will be water]. After it has drained fully [you should tilt the dryer on it's left side when viewed from the rear and then tilt back towards you to get all of the water] replace the cap and secure it with the spring lock. Now tilt the dryer on it's left side and let it drop from about 5cm. See if that resolves the problem, if not remove the left side panel - when viewed from front [ you need to remove the lid by unscrewing the two retaining scrfews at the rear and sliding it back, then remove 4 screws from the back panel that connect to that panel, there is one more screw at the top front of the panel]. Unplug the two hose pipes [red and clear] and remove the small retaining screw then pull out the complete housing [it will slide]. You can then see the black float which triggers the tank full switch. Clean it and any other gunk that is in the reservoir. If there is a lot of dirt then you may have to clean your condensor [see operating manual for instructions on how to do that]. Put it all back together and the 'full tank' issue should be cleared.
7/26/2017 11:53:19 AM • Tricity Bendix... • Answered on Jul 26, 2017
0answers
Goes through full cycle but does not heat to dry clothes
Check the thermal cut out which is situated next to the cycling thermostat , above the heater , they come as a pair .
3/6/2015 8:01:21 PM • Tricity Bendix... • Answered on Mar 06, 2015
Why is there no water in the tank after use, even when clothes are wet going into the dryer?
The pump sits in a sump behind the condensor if it is not blocked , then the pump is faulty
3/3/2015 10:38:31 PM • Tricity Bendix... • Answered on Mar 03, 2015
How to fit belt on a tricity bendix tm310w tumble dryer
round the pulley then around the tensioner then around the drum.
3/2/2015 4:41:00 PM • Tricity Bendix... • Answered on Mar 02, 2015
WHY IS THE CONDENSED WATER NOT COLLECTING IN THE WATER TANK
I am assuming you do not have a vent to the outside and you are using one of those little boxes/lint trap devices? You shouldn't be getting water coming out but it is natural to have high humidity hot air coming out (the water has to go somewhere). If you are using one of those traps, I would make sure it is at, or lower than the level of where the hose comes out of the dryer (allowing any moisture to come out and not be trapped in the hose in a low spot).
11/3/2014 4:38:51 PM • Tricity Bendix... • Answered on Nov 03, 2014
0answers
My tricity bendix tm320 heater wont heat on half heat but will heat on full heat
It may be as simple as checking your lint filter. If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
5/21/2014 5:27:13 AM • Tricity Bendix... • Answered on May 21, 2014
Tricity Bendix TM310W Electric Dryer Logo
88 questions posted
Top Tricity Bendix Dryers Experts
john h
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
View Most Popular
  • Tricity Bendix Dryers
Most Popular Question
no water in tank after use even when
  • Dryers
