20 Most Recent
Fujitsu "AOU24RLXFZ 24,000 BTU Halcyon HFI Outdoor Unit" Questions & Answers
Have a Fujitsu Halcyon mini split AC unit leaking on inside.
I have the same unit. The drain line will be outside and is linked to the condensate drain on the outside refrigeration unit. It will be a black plastic or clear polythene tube a half inch in diameter. The bottom is probably blocked. A tech may be able to do it from the inside by blowing compressed Nitrogen gas down the drain. The case obviously has to come off which should be a quick job just 7 screws according to the video help.
Fujitsu ducted RC aircon (25 yo) error code
The error code 2F00 indicates a problem with the indoor unit's microcomputer. It could be caused by a malfunction in the microcomputer or the communication error between the indoor and outdoor units.
Fujitsu AGU9RLF Operation Light Blinking
there might be a filter that needs to be changed or the machine needs service. Please check the troubleshooting section of your product manual to determine the specific meaning of the blinking light and the auto-off that's occurring. If you don't have the manual, then please call Fujitsu and request a copy be emailed to you. If that fails, you might need to take your product into a place like Geeksquad/Bestbuy for servicing.
Thank you.
