20 Most Recent Tricity Bendix AW1000W Front Load Washer Questions & Answers
0answers
Electricity keeps blowing when my Tricity Bendix washer (AW 1050) is switched on. I have checked the fuse in the plug and have cleaned the filter but it hasn't helped. Can you help?
Motor jam or motor winding is short. You have to check the motor and starting capacitor attached to the motor. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
6/20/2016 4:44:45 PM • Tricity Bendix... • Answered on Jun 20, 2016
Iv got a Bendix BIW103W, water runs to machine
i would check the water inlet on machine............take the hose off there should be a small filter inside. might be blocked..................
cheers
4/28/2016 8:25:03 PM • Tricity Bendix... • Answered on Apr 28, 2016
Why are clothes dripping wet after final spin?
There is a balance sensor in the machine that checks to see if the load is distributed for high speed, When that sensor goes bad, the machine wont spin the water out of the clothes. YOu need to check for spares
4/22/2016 3:58:13 PM • Tricity Bendix... • Answered on Apr 22, 2016
How to remove filter on tricity bendix 1000 washing machine?
tricity bendix aw1001w eco shower washing machine ...
? 1:11 www.youtube.com/watch?v=lJZrGLfYdtQ Aug 19, 2009 - Uploaded by whichwasher2007 my aunt's old tricity bendix. it says aw1000w on the front, but check ... How do you clean out mold in the ...
9/29/2015 5:28:56 PM • Tricity Bendix... • Answered on Sep 29, 2015
0answers
Water going in 2 the machine after the load is finished and the clothes r taken out
bad water inlet valve or control board? foes it do it even after u unplug it? if so then its ur water inlet valve if it stops after unplugging it its ur control board water-going-in-2-machine-after-load-cs4uo0ksqeekdm4wcgxnqiuz-3-0.jpg water-going-in-2-machine-after-load-cs4uo0ksqeekdm4wcgxnqiuz-3-2.gif water-going-in-2-machine-after-load-cs4uo0ksqeekdm4wcgxnqiuz-3-5.jpg ALSO CHECK THE WATER PRESSURE SWITCH BELOW water-going-in-2-machine-after-load-cs4uo0ksqeekdm4wcgxnqiuz-3-9.jpg water-going-in-2-machine-after-load-cs4uo0ksqeekdm4wcgxnqiuz-3-14.jpg water-going-in-2-machine-after-load-cs4uo0ksqeekdm4wcgxnqiuz-3-20.jpg
5/29/2015 11:31:17 PM • Tricity Bendix... • Answered on May 29, 2015
0answers
How many kg does it hold?
5 or 7
2/23/2015 9:46:21 PM • Tricity Bendix... • Answered on Feb 23, 2015
Washing machine wont drain
check pump
2/23/2015 9:42:45 PM • Tricity Bendix... • Answered on Feb 23, 2015
The dryer on the TRICITY BENDIX WDR1241W wont work
check element
2/23/2015 9:40:50 PM • Tricity Bendix... • Answered on Feb 23, 2015
Replace drum bearing do I need to split the tub in order to get bearings off of shaft
yes better to remove the unit
2/14/2015 11:04:44 PM • Tricity Bendix... • Answered on Feb 14, 2015
Why is the water not entering thepowder compartment
could b inlet valve stuck shut
2/14/2015 10:34:55 PM • Tricity Bendix... • Answered on Feb 14, 2015
Why will my machine not fill
check water is on or pressour switch fault
2/14/2015 10:33:40 PM • Tricity Bendix... • Answered on Feb 14, 2015
Nohotwateronwashcycles
probly heater element
2/13/2015 3:19:17 PM • Tricity Bendix... • Answered on Feb 13, 2015
How do i remove clothing stuck between door seal and drum on tricity bendix washing machine
Frankly the only way you can get them out if you can get hold of them is pull like hell, something will give hopefully the clothes, but probably won't be any good afterwards, otherwise this is not an easy task and you should get a repairer to do it. Not the best advice in the world. but in future any small items should be put in a pillow case to avoid this happening again.
11/26/2014 4:37:20 PM • Tricity Bendix... • Answered on Nov 26, 2014
Tricity Bendix AW1000W Front Load Washer Logo
253 questions posted
Top Tricity Bendix Washing Machines Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Tricity Bendix Washing Machines
Most Popular Question
main issues tricity bendix aw1000w
  • Washing Machines
