20 Most Recent
Acer (91.48R37.002) CD-RW/DVD-ROM (Combo) Burner Questions & Answers
Carpet cleaner cleaning solution
Carpets hold billions of tiny insects and dirt particles that thrive on what regular vacuum cleaners can't remove. The only way to rid your carpet of these pests is expert and professional carpet cleaning.
Geelong Commercial Cleaners, provides many specialized cleaning and restoration services in the Geelong region.
For more information visit here: http://www.geelongcommercialcleaners.com.au
5/22/2023 10:08:20 AM •
Acer...
Answered
on May 22, 2023
HOW I CAN RECORDER IN MY LAPTOP
Welcome to fixya
Hello
I have a solution for
this
Press Ok, Accept or
replay so we may get started
Your pre-solution is
coming up shortly
PLEASE
REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
1/16/2011 2:20:37 AM •
Acer...
Answered
on Jan 16, 2011
DVD Door Won't Open
I have this problem with my DVD rom too. I don't know if we have the same ones or not. I took mine apart to try and diagnose the problem, and it turns out that there was this thing inside that wasn't dropping down all the way to allow the tray to slide out, it was staying locked in place.
I was unable to find a cure for this.
However, I found that when I press the button to open the DVD rom, when it fails to open, I give the top of mt computer a slap, and it un-locks the mechanism and the DVD tray slides out properly.
I hope this helps.
4/28/2009 12:22:42 AM •
Acer...
Answered
on Apr 28, 2009
Mpowering technology pop up
Couldn't get rid of mpowereing technology pop up. Tried every solution offered by the internet. Finally I noticed when I powered up my computer the pop up showed up even before the computer loaded anything. I turned off the power to the monitor and powered it back up an viola, pop up gone. The Acer monitor had generated the pop up.
My Acer X1110 switches off as soon as blue light comes on?
it needs service, and service manuals are hard to find on anything by the likes of ACER.
this projector worked for 12 long years, did you own it 12 or bought a bad projector, no history told as I can buy dead projectors all day long. and hard nut problems even hacking done.
Acer X1110 data projector Standard throw projector..
did you know most projectors have serious grade protective devices inside??? (tamper and overheating are 2)
did you read owners manual page 32 yet, errors.
LED codes.?
there are 4 LED, and all 4 matter, projector turned (ON) (not one =1)
also in pairs glowing and also if blinking or not, so read page 32
it tells all that.
my guess is overheat failures, even cold, due fan slow or packed in lint after 12 years of use and no service done,.
https://manualzz.com/doc/49497108/acer-x1110-user-manual
some have dust filtler
a shop first cleans is out first, and check fan RPM with and LED tachometer.
this is all SOP.
''e'' button :acer empowering technology
That button can be set using the utility on your programs list
It maybe that you accidentally turned it off or set it to do some other task.
Start there first before re-installing the program that sets it.
That is on one of the cds that should have come with it and can be installed by itself.
