20 Most Recent Acer Aspire 1710 Notebook Questions & Answers
www.acer.com
Acer Aspire 1710... | Answered on Jan 01, 2014
If the tray does not lock closed then the solenoid locking mechanism is faulty meaning a new drive may need to be installed.
If however this is a random occurance then I would put it down to a software application.
I may be possible that your computer has files that are ready for burning to disk, either created on purpose or by acident. Find these files and try to cancel them.
Take care!
damnor01
Acer Aspire 1710... | Answered on Sep 14, 2012
use my acer aspire daily, went to put a memory stick in and it just died, no power at all but power light on charger still showing green
Acer Aspire 1710... | Answered on Sep 13, 2012
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Acer Aspire 1710... | Answered on Aug 17, 2012
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.https://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-https://www.fixya.com/support/r3559128-wireless_router_security
Acer Aspire 1710... | Answered on Aug 01, 2012
tim.id.au/laptops/acer/aspire%201710.pdf
open dis site
Acer Aspire 1710... | Answered on Jul 24, 2012
To repair missing orcorrupted system file/s, boot up with the Windows installation CD then -Press R to repair wheninstructed.Press 1 or Enter to repairthe C:\Windows folder.Then type chkdsk /r and then press Enter.The repair process willtake quite a long time.
Let it charge for a good 24 hours, you will get maxium capacity out of the battery.
Acer Aspire 1710... | Answered on Jul 17, 2012
You will need to contact the software maker.
Acer Aspire 1710... | Answered on May 17, 2012
I'm not understanding what it is you are trying to say,it sounds like you are trying to describe two problems.
Projector won't flash? Are you saying nothing displays on the Screen?
And what just shows blue blink on it's power button the computer?
Blinks and Beeps tell the technician what is wrong with your system. Notice how many times it blinks and where the blinks are long or short. There is a pattern to to blinks for example (3 short blinks or 1 long blink followed by 2 short blinks).
I'm going to assume your system has a memory chip problem and when you press the power button it just blinks and nothing ever happens, not posting on the lcd screen at all.
Remove the Power Cord, Remove the Battery, Turn the laptop over and Remove the screw that secures the Memory Cover and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Acer Aspire 1710... | Answered on Apr 08, 2012
Check to be sure the ribbon connections are tight. If they are and the previous screen worked perfectly before it was damaged (assuming it was replaced because it was cracked etc) then you may need to return the screen and try another one.
Acer Aspire 1710... | Answered on Jan 21, 2012
Popping sounds are bad. Usually shorting electrical somewhere. Is the light on the power brick green? flashing? Red?
It's either a bad power brick or a bad connection in the laptop. You can buy a power brick fairly cheap, but if its out of warranty and the problem is not in the brick its probably not worth it to fix.
Acer Aspire 1710... | Answered on Jun 28, 2011
It is likely that the backlight for your screen is faulty or needs replacing. This is not a job you can usually tackle yourself, you will need to take it to a dealer to have the unit repaired.
Acer Aspire 1710... | Answered on Oct 21, 2010
It sounds like you are or have lost your backlight. In most cases this can be the inverter, it sits under the lcd panel behind the lcd bezel. Unless the unit was dropped or suffered a shock of some kind, I don't think it would be a broken ccfl backlight bulb. Check for loose connections at both ends of the inverter, sometimes these connectios get pulled because they run through the hinges and can get caught or rubbed bare. Below is the link to the service guide that will help in the disassembly. Inverters can be bought on Ebay for under 25 bucks. There is always the chance that this is the ccfl bulb, it is built into the lcd panel itself and therefore it is more cost effective to replace the entire panel then try to disassemble the lcd panel and replace the ccfl bulb. Good luck
http://tim.id.au/laptops/acer/aspire%201710.pdf
Acer Aspire 1710... | Answered on Jul 25, 2010
when you checked with different monitor if you are getting lines that means its and issue with the video card , reinstall the video card driver should resolved the issue
www.support.acer.com you can get the drivers
Acer Aspire 1710... | Answered on Jul 05, 2010
make sure the fans are running and its not overheating
Acer Aspire 1710... | Answered on Mar 03, 2010
Yes, a second hand one will be just fine. Just make sure it's the exact same model, otherwise it wont work.
Acer Aspire 1710... | Answered on Feb 15, 2010
Hi
This is a common problem. The problem is the inverter. I changed mine OK. Actually I changed the inverter once and the whole LCD screen twice! Now happy with working 1711.
two inverters here on ebay
http://cgi.ebay.com/ACER-Aspire-1700-1710-LCD-INVERTER-1702-1711-1712-1714_W0QQitemZ150404840875QQcmdZViewItemQQptZUK_Computing_LaptopAccess_RL?hash=item2304d3bdab
http://cgi.ebay.com/Acer-Aspire-1700-1710-lcd-inverter_W0QQitemZ150404836278QQcmdZViewItemQQptZUK_Computing_LaptopAccess_RL?hash=item2304d3abb6
search this massive thread and you will find instructions on fitting the inverter.
http://www.notebookforums.com/thread19756.html
Cheers
Acer Aspire 1710... | Answered on Feb 01, 2010
hello , remove any third party devices attached to the computer and restart the computer , make sure you have installed all the system files provided on the acer system disk.
Acer Aspire 1710... | Answered on Oct 22, 2009
Acer Aspire 1710 Notebook Logo
41 questions posted
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
lines thy another monter
  • Computers & Internet
