20 Most Recent GE GTWN4250DWS 3.9 cu. ft. capacity top load washer Questions & Answers
How do I increase water level?
The water level is controlled by the water level switch. If set to the highest fill level----thats all you get. The government has interfered with manufacturers to try and conserve water so very few of the new machines fill as high as they use to. There use to be a factory set screw on the water level switch for factory adjustments only but if you play with it wrong, you may end up flooding the basement with an over fill problem.
5/2/2016 7:04:28 PM • GE GTWN4250DWS... • Answered on May 02, 2016
2answers
I have a GE Washer GTWN4250DOWS. I was washing my son bedding and his mattress pad got stuck under the agitator. I have pulled and pulled on it. In need of help we dont have money to call a repair pla
Remove the dispenser cup on the agitator. Then remove the 7/16 bolt that holds the agitator on and lift the agitator out.
4/26/2015 8:14:31 PM • GE GTWN4250DWS... • Answered on Apr 26, 2015
What is causing washer to be very loud and bounce when spinning
When you did not overload it, the only reason I can think of is a bad shock-absorber. When this happens all the time you are washing, it must be that. Sometimes every thing in the machine clumps together and you have the same effect. If this does not happen all the time, don't worry.
1/17/2015 9:02:58 PM • GE GTWN4250DWS... • Answered on Jan 17, 2015
How do I set water temperature for the rinse cycle?
I suppose you have looked at the owners manual, on the page below, it seems to indicate knob B. but it is unclear GTWN4250DWS GE 3 9 DOE cu ft stainless steel capacity washer GE Appliances
12/24/2014 9:44:47 PM • GE GTWN4250DWS... • Answered on Dec 24, 2014
175d2750g308
They should know that info with out asking you if the are truely repair people.
2/5/2014 12:08:06 PM • GE GTWN4250DWS... • Answered on Feb 05, 2014
0answers
Can I get new brushes for my GE handmixer 56M17
No there’s no brushes for GE handmixer
3/10/2024 8:12:40 PM • GE Washing... • Answered on Mar 10, 2024
GE WSLP1100A0WW not agitating
It sounds like the clutch is slipping https://www.google.com/search?q=GE+WSLP1100A0WW+not+agitating
Top Load Washer - Fills But Will Not Agitate
GE Appliances https://products.geappliances.com > appliance > gea-sup... If the lid switch probe or magnet is missing or damaged, the washer will not agitate or spin, even with the lid closed. Missing: WSLP1100A0WW ‎' Show results with: WSLP1100A0WW
SOLVED: GE WSLP1100A0WW not agitating
Fixya https://www.fixya.com > ... > Washing Machines > GE 17 hours ago - Ge top loader washer agitator does not work To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator.
Ge Washing Machine - Washer Won't Spin Or Agitate
Repair Clinic https://www.repairclinic.com > RepairHelp > Ge-Washe... If a washer is not spinning or agitating, you should first determine if the drive motor is running and if power is reaching the drive motor. If no power if ... ..
3/5/2024 1:09:38 AM • GE Washing... • Answered on Mar 05, 2024
GE WASHER MODEL GFWH1200HOWW RUNNING EXTRAAA LONG ON WASH CYCLES??
Hello Heather Good to see you again. Also check the small strainers on the water connectors. They can block up with limescale and debris. While the connectors are off, turn on the water into a bucket or a sink. You should have a VERY powerful jet of water. Anything that will reduce flow will lengthen the fill time and therefore to total wash time due to fill and rinses. When it pumps out, also check you have good flow in the drain hose and items can jam in the ridges and catch lint enough to block them almost completely. One clever thing to do is whilst the water inlet connectors are off, unlock the drain hose, unhook the part that makes the hook, put the round connector in the hose and wrap a tea towel around it. Get someone to turn the water on full bore whilst you are gripping the two hoses together. Run it for a full minute. Water will be flushed into the machine through the pump in reverse. Put everything back and run a rinse and spin with nothing in it, look at all the black lint that is pumped out! I did that once at work and found an apple stalk that had lodged across the ridges of the drain hose which had 90% blocked the pipe. ..
2/23/2024 8:08:04 PM • GE Washing... • Answered on Feb 23, 2024
2answers
Stripped connection at the cold water intake into washing machine
If your inlet valve itself is stripped then you have to replace the valve. The plastic thread is part of the inlet valve. If its only the screen in your inlet valve you can remove the screen and replace it. However if you crossthread anything plastic it HAS to be replaced.
If you give me your model number of the washer usually the wpl 4318046 can be used as an inlet valve which is a cheaper alternative than your local parts distributor would tell you. GE parts on avg are 30% more expensive than anything else. On ANY ge appliance there is usually a way around there replacements with some minor altercations. I wish this site had a way you could contact me directly. I just joined so am not an expert yet but ive done my time in the field. If i could give you any expert advise its DONT BUY GE, OR LG.
Let me know if this helps.
12/11/2023 6:33:13 PM • GE Washing... • Answered on Dec 11, 2023
GE GTWN4250DWS 3.9 cu. ft. capacity top load washer Logo
28 questions posted
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
  • Washing Machines
