20 Most Recent Roper RS22AQXKQ Side by Side Refrigerator Questions & Answers
This sounds like a defrost drain problem. Behind the panel in the back of freezer is a heater that defrosts the evaporator and below that is a drain hole. They will occasionally get clogged or just freeze over Pour hot water down it until it thaws then check to see if the water drains normally. If it drains after thawing then get a small length regular electrical wire and twist one end around the heater. You should get enough to extend the other end 2 or 3in into the drain hole. Now when the heater turns on it will heat the wire and thaw any ice in the top of the drain.
If you can't get water to drain then there is something clogging the drain tube and you'll have to find a way to clear it. I use a steamer that has a small tip to build pressure and force the clog out. Hope this helps.
Roper RS22AQXKQ... | Answered on Jun 25, 2018
Could be that the gearing on augur is tripped and that is why it stops.
Check attached site for parts and pricing.
Search Over 2 1 Million Appliance Parts
Roper RS22AQXKQ... | Answered on Sep 01, 2017
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
8
Roper RS22AQXKQ... | Answered on Oct 10, 2014
Not all fridges with water dispensers have integral filters. Several have an external in line filter fitted to the supply pipe.
Roper RS22AQXKQ... | Answered on Jul 16, 2014
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Roper RS22AQXKQ... | Answered on May 03, 2014
Just measure the outside height, depth and width. A replacement of the same or bigger dimensions will hold as much or more stock
Roper RS22AQXKQ... | Answered on Apr 30, 2014
Roper RS22AQXKQ Side by Side Refrigerator Logo
232 questions posted
Top Roper Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Gil Shultz
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Roper Refrigerators
  • Roper Refrigerators
Most Popular Question
just want know size replace
  • Refrigerators
