20 Most Recent
Reliance 606 Series 40 Gallon Electric Water Heater - 6 40 DORS Questions & Answers
Where do I find the Temp. Control so I can turn it up.
If it's gas the control usually is at the bottom of the tank where the gas line comes in.
If it's electric there should be a little trap door either at the top or bottom and the heat control is behind that door. The door is usually held in place with a screw There is a little dial with numbers you can turn up or down. There are electrical wires that you should not touch as well.
HOW TO REMOVE ANODR ROD FRO 606 RELIANCE
It is the 1" or 11/8" hex nut on the top of the water heater some where buy the supply line. As for the anode rod it could be either magnesium or aluminum depending where it was sold. If you are going to change it out call your water provider and ask which would be better for your area and water. To remove you need to turn off the electric, shut the water supply and drain off some of the water so it wont overflow, then it simply unscrews. Use teflon tape or sealer on the thread before installing the new one, then turn everything back on and purge the air from the system by opening a faucet.
WHERE IS THE ANODE ROD ON A 606 RELIANCE HEATER
It is the 1" or 11/8" hex nut on the top of the water heater some where near the supply line. As for the anode rod it could be either magnesium or aluminum depending where it was sold. If you are going to change it out call your water provider and ask which would be better for your area and type of water.
Are all 25VS FV sensors equivalent?
I personally wouldn't replace a safety device (placed there by lawyers, lawsuits and the all knowing government) with anything other than OEM. While it's very likely that one manufacturers flammable vapor sensor may interchange on another brand of tank, I think it's highly unlikely that EVERY manufacturers sensor will work on every other brand of tank
