20 Most Recent Kenmore HE2 Plus 3.6 cu. ft. Super Capacity Front Load Washer Questions & Answers
chjeck the pump for any blogg
Kenmore HE2 Plus... | Answered on Jun 05, 2014
If the door lock is engaging, then there could be a few things causing the problem. These things are as follows:
1) The water valve is bad - you can check this by seeing if when you turn the machine on if power, 115vac is being applied to it. If so the valve is bad, if not read forward.
2) There is a part called the pressure switch, it controls the amount of water that flows into the machine. Its connected to the drum by a 1/4" tubing. You'll need to check to make sure that nothing is obstructing the tube.
3) Take the bottom of the machine off, called the kick plate. Inside there is a tech sheet with diagnostic walk through's that will carry you the rest of the way
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Kenmore HE2 Plus... | Answered on Jun 18, 2012
IF you take the panel off the is below the door, there is a drain plug and you should take it out. YOU will get lots of WATER. Be ready. Clean this out and try again. The issue is most likely the water solenoid valve is bad or the board that controls it is bad. You can also find the tech sheet when you look for the drain. It has all the tests that you can run.
Kenmore HE2... | Answered on May 17, 2019
There are two control boards (parts 3 and 6) shown here: http://www.searspartsdirect.com/model-number/11047571601/0582/0153200.html . Make sure to look at the Control Panel diagram. Part 3 is http://www.searspartsdirect.com/part-number/8540490/0026/110.html?modelNumber=11047571601&categoryName=Residential%20Washers&brandName=KENMORE . Part 6 is http://www.searspartsdirect.com/part-number/W10022320/0026/110.html?modelNumber=11047571601&categoryName=Residential%20Washers&brandName=KENMORE . With these part numbers, you should be able to find them online. They will be listed as Whirlpool or Whirlpool OEM parts.
If you add a comment with the problem that led you to have a technician look at the washer, I will confirm which board is which. I suspect part 6 is the B board but I'm not certain of that.
I hope this helps.
Kenmore HE2... | Answered on Apr 20, 2017
unplug--see if it resets--if not--the control box is bad--about 300 for the part
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/david_2f6e03df6c124197
Kenmore HE2... | Answered on Jan 13, 2015
Kenmore HE2 Plus 3.6 cu. ft. Super Capacity Front Load Washer Logo
Popular Tags
16 questions posted
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
James Hensley
James Hensley
View Most Popular
HE2 Kenmore
  • HE2 Kenmore
Most Popular Question
kenmore front loader washer powers but
  • Washing Machines
