20 Most Recent
Daewoo DWD-WD1353WC 4.5 Cu. Ft Capacity Washer 1 300 RPM 11 Cycles Chrome Questions & Answers
How to clean drain hose
Drain hose very rarely plug up. you can remove the hose and check it but I would bet the relay that opens the drain on the washer is not working correctly. If you have have a bit of tool skills they are relatively easy to replace but check the hose first.
8/25/2017 11:50:36 PM •
Daewoo...
Answered
on Aug 25, 2017
Daewoo Mini Washing Machine Error B8
It could be the starter capacitor for the electric drive motor. You may also look to see if the brushes that sit on the armature are not stuck and free to travel while sitting completely flat on the armature to make the correct contact. There is also a speed sensor for the motor that may be bad. CAUTION: Make sure the machine is unplugged and the capacitor is drained to avoid shock.
