20 Most Recent
Whirlpool WTW5500XW 3.6 cu. ft. Cabrio Top Load Washer with Precision Questions & Answers
Wtw5500xw2 will add some water, senses for a very
Un plug it for a few minutes or even overnight and plug back in, that will reboot the electronic control, if that doesn't fix it and you do not have a good honest local repair shop call Sears. Good Luck
11/7/2013 1:09:12 AM •
Whirlpool...
Answered
on Nov 07, 2013
Can the water level be raised?
1st thing to check, would be water level sensor, usually a pressure switch, one end will be connected to the outlet pipe the other to a approx 75mm dia unit towards the top with two wires on it. clear that pipe
3/4/2013 9:13:37 PM •
Whirlpool...
Answered
on Mar 04, 2013
Whirlpool Cabrio Washer fills but will not do anything else
1. Remove the drain hose from the drain and try to drain the water from the washer. To do this plug the washer back in and attempt another drain cycle. If water does not come out of the drain hose then you now know that the plumbing is in good working order. 2. Place the drain hose back into the drain and remove the washers cabinet. 3. You will now be able to see the pump and it should have two hoses attached to it. 4. Disconnect the hose coming from the basket. If water comes out you will know that nothing is clogging the basket. 5. If both of these tests come out good you now know that the problem is the pump. 6. Make sure you write down all relevant information such as the washing machine model and serial number. 7. Head to your local hardware store and buy a pump (they typically run about $15.00). 8. Remove the old pump and install the new one (make sure the washing machine is turned off and unplugged). 9. Test it. Let it run through a cycle to make sure everything is installed and working properly. 10. If it is still broken call a repairman or ask a handy friend to check it out for you.
9/21/2012 11:44:18 AM •
Whirlpool...
Answered
on Sep 21, 2012
