20 Most Recent
LG DLG2102W 7.3 cu. ft. Front Load Gas Dryer FACTORY REFURBISHED FOR USA Questions & Answers
NOT HEATING
Check for power to the heater when the program comes to the set cycle to heat, if there is no power then the control board is the suspect. If not the heater is OPEN Circuit with a failed element or there is fault in the connection or wiring. Trace and confirm.
I have got a front
Is the washing machine giving off a hot machine oil smell or making a grinding noise when the tub is turning? I've had to replace the drum bearings several times on LG front load washers. The first sign that the bearings are going are loud noises when the drum is spinning and eventually the hot machine oil smell. The bearings can be replaced but they usually last only 6 months to a year. The bearings are put on with a press at the factory and unless you are very accurate, you won't be able to get them on exactly straight and they will wear out quick.
10/27/2023 10:07:56 PM •
LG Washing...
Answered
on Oct 27, 2023
